Old 08-19-2007, 06:12 PM   #1
Sport/Truck
Sierra Grande Club
Sport/Truck's Avatar
Roller rockers & stock valve covers…..
I need to know if stock covers will fit with roller rockers. The guy at summit says they will if I double up the gasket. How much do I really need? I got some sweet looking stock valve covers, and I don’t want to have to sell them.
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe.
Sport/Truck is offline   Reply With Quote
Old 08-19-2007, 06:17 PM   #2
bad_turbo
turbo enthusiast
bad_turbo's Avatar
Re: Roller rockers & stock valve covers…..
Great looking valve covers!! I had some Dart heads on my small block with roller rockers and had no trouble with clearance for stock valve covers.
"But daddy, I didn't hit them all with a stick"...what my 6 year old tells me when I pick him up from school early for fighting "
bad_turbo is offline   Reply With Quote
Old 08-19-2007, 06:21 PM   #3
Sport/Truck
Sierra Grande Club
The valve covers you used were different than mine, but what rockers did you use? I really hope I can squeeze rocker under my stock covers....with out stacking a ton of crap under them.
s/t
Old 08-19-2007, 10:24 PM   #4
Ram-Man
Ram-Man's Avatar
Edelbrock makes a valve cover gasket that is 5/16" thick. No need to stack them. Summit carries them.
Porterbuilt 8 Lugger
http://67-72chevytrucks.com/vboard/s...d.php?t=691739
Ram-Man is offline   Reply With Quote
Old 08-19-2007, 10:50 PM   #5
Sport/Truck
Sierra Grande Club
Is that all I'm going to need to to fit roller rockers under stock v-covers?
thanks!
s/t
Old 08-20-2007, 01:51 AM   #6
BurnoutNova
BurnoutNova's Avatar
my truck has comp roller rockers and stock valve covers.. never had a probleom yet
BurnoutNova is offline   Reply With Quote
Old 08-20-2007, 07:00 AM   #7
What`s the ratio on the arms?I believe 1.5s will work,but designs vary,Do you have them selected?Sorry,I don`t know where you`re at with your build lately.Is it all done and you`re just wanting to put those on it?I was just looking at the Summit book wondering the same thing.I`m dropping a 327 off at my machinist this evening and it hit me that I had better start ordering some parts or at least tell him what I want.I`m going to tell him what I want from the motor and listen to his recommendations.But,I know I don`t want tall valve covers.
Old 08-20-2007, 09:54 AM   #8
Sport/Truck
Sierra Grande Club
Are your heads stock cast iron? What’s the part # on the comp roller rockers?
Thanks!!
s/t
Old 08-20-2007, 10:02 AM   #9
Sport/Truck
Sierra Grande Club
I’m going to stay with 1.5 unless someone can change my mind. I really want this to look stock (keep the stock v-covers).
My motor isn’t in yet…too busy. I was going to paint the frame under the engine, but I’m thinking it won’t look right unless I un-bolt some components like a-arms, fuel lines etc.
I’m definitely going to paint the firewall before I put the engine back in.
s/t
Old 08-20-2007, 11:32 AM   #10
hyarbour
If worse comes to worse, Summit has valve cover spacers that'll raise them about an inch. I put them on mine mostly because I hate the mess when I have to test run it with the covers off.
hyarbour is offline   Reply With Quote
Old 08-20-2007, 11:56 AM   #11
Richard H.
Spanked once
Richard H.'s Avatar
Might be a problem if the rockers have poly-locs.
In April I decided to renew every thing up front on my truck But I have great help.
Richard H. is offline   Reply With Quote
Old 08-20-2007, 12:45 PM   #12
CST*TEN in Katy
Be sure you don't put the stock valve covers on upside down or you WILL knock holes in them. I did with a .440 lift cam and stock stamped rockers, even with the fat gasket.
1970 CST-10 owned it 26 years, finally back on the road after a 10 year rest.
1989 Suburban
1971 Sleekcraft 455Olds Berkeley
1992 SC400 pimp ricer
CST*TEN in Katy is offline   Reply With Quote
Old 08-20-2007, 01:27 PM   #13
Schralper
Schralper's Avatar
I run 1.6 intake/1.5 exhaust rockers, Comp and Crane w/ .510+ lift roller cam.
The stock Crane locks are a lil big on the top, just dimpled the stock v.c w/ thick felpro gasket. ARP Permalocs work great and fit fine.
I've been running the stock covers for the sleeper look but cast Al are WAY quieter! Especially w/ roller cam and rockers.
Schralper is offline   Reply With Quote
Old 08-20-2007, 04:39 PM   #14
BurnoutNova
Thanks!!
s/t
i have the facory heads on my k10... i think there 993's?? its been a couple years since i biult it. the comp rockers are the roller tips, with polylocks, otherwise the motor is stock.
on my nova, i have harland sharp 1.5 ratio full roller rockers and for a while ran stock corvette valve covers, and a friend of mine has a 86 k10 with proform roller rockers and stock orange covers and there fine. he has polylocks also
if your running 1.5" you dont have anything to worry about, hell i be 1.6" would even clear. you should only need tall covers if your running stud girdles
Old 08-20-2007, 10:32 PM   #15
Sport/Truck
Sierra Grande Club
Thanks for the clarification B/N. So the Comp cams are only roller tipped?
I went to the local shop Checker Auto. They had some comp cams cast aluminum roller rockers $$280. They also had some proform ($150) like you mentioned- they are a better quality extruded aluminum. Are the proforms any good? Anyone else running these?
s/t
Old 08-21-2007, 10:01 AM   #16
BurnoutNova
ive ran proforms, and a few of my friends still do. there fine quality. the only thing i diodnt like is the polylocks that come with them. mine kept backing off so i got some new ones, but other than that they were great.
and yes my comp rockers are just roller tiped. i didnt even plan on using them on my truck, but i had them laying around so i used them
Old 08-21-2007, 10:07 AM   #17
84_chevrolet
Truck CRAZY!
84_chevrolet's Avatar
Cool Re: Roller rockers & stock valve covers…..
I have 1.6 roller rockers on a 350 with the centerbolt valve covers and they dont hit. It also has a .500 lift cam in it too.
84 Chevrolet stepside, 350 with .60 over pistons, aluminum zr1 heads, doug herbert .500 lift cam, 1.6 roller rockers, elderbrock intake with a 600 holley carb, mated to a 700r4, 208t-case and 4-11 gears,33 goodyear wrangler mtrs
84_chevrolet is offline   Reply With Quote
