Old 08-19-2007, 09:30 PM   #1
frankdatank01
Name that electical component....
Anyone able to tell me what these are and do?
On a 1970 CST10 with the 70s 455 buick 455. Still has external regulator and HEI.
I have a new wire harness and just want to make sure I dont remove something that I might need.
Thanks all.
Tank
frankdatank01 is offline   Reply With Quote
Old 08-19-2007, 10:32 PM   #2
rob32472
Re: Name that electical component....
looks like dual horn relays
rob32472 is offline   Reply With Quote
Old 08-19-2007, 10:54 PM   #3
truckdude239
truckdude239's Avatar
horn rtelay is under the dash i got them on my truck they hooked up but no clue what they go too but someone will pitch in
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 08-19-2007, 10:59 PM   #4
Sport/Truck
Sierra Grande Club
Sport/Truck's Avatar
The suspense is killing me…..Please someone….
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe.
Sport/Truck is offline   Reply With Quote
Old 08-20-2007, 01:49 AM   #5
BurnoutNova
BurnoutNova's Avatar
my truck has the wires there for those... but there not hooked up to anything. ive been wondering what those wires went to forever!
BurnoutNova is offline   Reply With Quote
Old 08-20-2007, 02:52 AM   #6
Peter82
Everything is Custom
Peter82's Avatar
i dont know how many of you guys have this but it might help. they are for wire chasing.
Peter82 is offline   Reply With Quote
Old 08-20-2007, 06:41 AM   #7
72armyswbtruck
72armyswbtruck's Avatar
When I get home I have an ultra cool 71 Chevy Repair manual (earlier repairs for the new vehicles in 71) anyways it has this ultra cool road map where every component is given an number to where it connects to like on a map. Part 72 dg a3 (obviously the part #, then dg for color of wire then A3 for the location of the part that the wire hooks into and what). Let me check when I get home.
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!"
72armyswbtruck is offline   Reply With Quote
Old 08-20-2007, 08:51 AM   #8
cdowns
cdowns's Avatar
the 2relays for the dumdass useless transmission spark control was a febel attempt at some type of emissions control by gm
Old 08-20-2007, 04:29 PM   #9
Blazer1970
Blazer1970's Avatar
Yes, they are for the TCS (transmission controlled spark) system.
Blazer1970 is offline   Reply With Quote
Old 08-20-2007, 04:34 PM   #10
BurnoutNova
anyone have more info on this?
is this why there is what looks like a pressure sensor on one of the ports ion the pass side of my trans? i also saw it on my friends all originla 70 blazer when i rebiult the transmission it it.
i'd never seen a switch like that on a th350, only on th400's for the kickdown
Old 08-20-2007, 10:42 PM   #11
truckdude239
umm if thats the case why do i have it on a 3 speed? lol
David fuller
2000 Tahoe 5.3l 378
Old 08-20-2007, 11:00 PM   #12
WorkinLonghorn
WorkinLonghorn's Avatar
From a period repair book;"TransmissionControlled Spark Advance; The vacuum solenoid that was used in 1970 is changed to a Combination Emissions Control (CEC) solenoid and has two functions: it controls distributor advance and acts as a deceleration throttle stop in high gear to reduce emissions." It goes on to mention the presure switch on the trans,the relay, AND a "time delay relay". It also lists a system for manual trans models and trucks.Brian
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, stereo speakers, 2nd owner, Work-Truck supreme.
WorkinLonghorn is offline   Reply With Quote
Old 08-20-2007, 11:42 PM   #13
jhow66
jhow66's Avatar
In other words-get rid on them.
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 08-21-2007, 01:58 AM   #14
66skylarkpost
66skylarkpost's Avatar
did someone say buick 455 ?
'70 k-10 longbox- mid 70's drivetrain 350/350 487x heads 10.1:1 flowmasters ,35's 3.73's auburn posi ,rear shackle flip. '72 short stepside U.S. forestry truck, '73 455 buick,400 turbo,dropped 2"-4 1/4" ,3.07 posi,:'89 silverado 1500 ,OK truck ,5.7 holley tbi ,trick 700r4 3.07 auburn posi ,and my '66 skylark ,'73 centurion and my '84 monte carlo imca stock car
66skylarkpost is offline   Reply With Quote
Old 08-21-2007, 10:47 AM   #15
WorkinLonghorn
LOL, yeah. Unless of course you live in California and current proposed legislation continues to pass (currently with some transportation committee) and ALL older vehicles are again required to pass inspection and testing! But then you wouldn't get by with a 455 either.
