Old 08-19-2007, 11:00 PM   #1
steverino66
brake rod swap for power booster?
I'm stuck - putting an 83 brake power booster in my 66, looks like I need to use the '66 rod to get enough length for pedal travel. (The 66 rod is adjustable for length). I have the 83 booster apart, but can't figure out how to get the small barrel-shaped end with the spring underneath off the end of the 83 rod. And will the 66 rod attach properly if I do get the 83 apart?
I know a pic would be helpful here, but no digital camera available right now. Any help appreciated. Anyone have a clue?
steverino66 is offline   Reply With Quote
Old 08-20-2007, 01:33 AM   #2
Woogeroo
Lightbulb Re: brake rod swap for power booster?
here is a link to some pictures of my brake rod that was on my '65 c10, which has a later model, 69 gmc(according to NAPA parts books) dual master cylinder:
http://woogeroo.5gbfree.com/Matraca/.../05222007.html
dunno if that helps or not.
-W
Woogeroo is offline   Reply With Quote
Old 08-20-2007, 02:20 AM   #3
Captainfab
60-66 Nut
I've not done it this way before. They way I've done them is to cut both rods so that you use the the original booster rod from the booster to under the dash in a convenient area. Then cut the original rod from your truck forward from the pedal at a point that meets the booster rod, and weld the two together. You need to make sure you leave yourself enough adjustment in the rod to compensate for any error there may be in the final length.
If you don't have welding capabilities, just do the cutting and fitting and take it to a reputable welding/fabrication shop. They shouldn't charge much to weld it for you. Hope this helps
Old 08-20-2007, 10:41 AM   #4
steverino66
Thanks for the info, guys - looks like I'll probably have to go the welding route on the rod if I use the booster I have.
Or I may just save up for one of the really cool aftermarket units with the correct rod, MC and proportioning valve attached. Sad part is, they cost more than the ENTIRE 83 parts truck I bought!
Old 08-20-2007, 10:51 AM   #5
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Thats exactly what I had to do on the Chief....Although I just lengthened the stock rod with some round stock. No booster just a manual master out of a 67 Impala.
John
What the Heck is that ??
CURRENT BUILDS:
62 BurbMaster
Other Builds:
My '63 C-10,LWB,CC,BBW
'06 HD StrAight Axle Swap
Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build
AMERICAN CUSTOMS & CLASSICS (831) 630-1965
www.ACCHOLLISTER.com
ACC on FACEBOOK
"Rest in Peace, Mom & Dad ... I will see you again someday!"
ChiefRocka is offline   Reply With Quote
Old 08-20-2007, 01:32 PM   #6
satin64
satin64's Avatar
any pics of what you did chief?
how much did you add?i was planning on getting a imp m/c like yours.
satin64 is offline   Reply With Quote
Old 08-21-2007, 12:38 AM   #7
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
I can't rememeber if I posted it on my build thread or not.....(?)
If not, I would have to take a pic under my dash for you...
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 08-21-2007, 04:08 AM   #8
satin64
satin64's Avatar
i looked through your build and didnt see it.im planning on useing the dual until i install the power unit and disc brake setup.
