08-20-2007, 01:03 PM | #1 |
Smoking during warm up?
Hi guys,
I'm about to put my 1972 Blazer back on the road after a 5 year hiatus. It still has the original 350 engine in it that has at least 123,000 mile (maybe 223,000 miles). It runs strong, but it used to smoke like H*@L when I would start it up cold. Once it warmed up, no smoke. I when I say smoke, I mean lots of it and for like 5-10 minutes until it was warmed up. It was a white-grey sort of smoke, not really very blue. The natural culprit would be the valve seals, which probably do need to be replaced. But would valve seals cause it to smoke for so long? I was wondering if it may have something to do with the carb (too rich maybe), or low compression in one of my cylinders (haven't done a compression check on it). The oil is not milky or grey, so I don't think there is water in it, and it doesn't smoke forever like it would with a blown head gasket or cracked block. It smoked so bad, my next door neighbour would come out and complain EVERY time I started it up (hence, it being off the road for 5 years). Any ideas? Thanks, Rod
1987 GMC Suburban 1/2 ton 4x4 (Beater) 1998 GMC Suburban 2500 4x4 1972 Olds 442 Convertible 2006 GMC 2500 Duramax Crew Cab (Sold) 1972 Blazer 4x4 (Sold) |
08-20-2007, 02:38 PM | #2 |
GEARHEAD
Re: Smoking during warm up?
The valve guides are probably worn pretty bad. That, along with bad seals will make it smoke pretty good. Sounds like it's time for a good valve job.
If no one knows what you're doing, they can't tell you you're doing it wrong HG's Dream Car Build - Shelby Cobra Kit Build your own adjustable track bar 71 Long Fleet C/10 72 Jimmy 4x4 (Junkyard Jimmy) HG's Plow Truck '78 K35 Dually Bigass Farm Truck HG's thread of miscellaneous stuff |
08-20-2007, 09:00 PM | #3 |
GMCDAC
What HGS_Notes said is right on in my opinion.
When the choke is shut, it causes a higher vacuum which will draw more oil thru worn valve guides. As the choke opens, smoke decreases. My Jimmy was doing the same thing when the engine was pulled at 153K. Later---DAC
1970 GMC K5 Jimmy Custom 4X4 Mom's driver from 1971 to 2001!! Under rebuild! 1972 GMC C2500 Pickup owned since 1979 Needs a rest and refurbish! 1955 GMC 100 2nd design driven almost daily! Rest In Peace Mom. "Dolly" 7/15/23 - 5/18/09 GMC driver for 30 years! |
