20" Wheels..... what offset do I need?
What offset do I need to go with 20" wheels on a 1969 Chevy C10? I'll be running 20's in the front and rear and need the offset. I just finished installing the Air Ride Suspension on the front and rear.
Thanks! Last edited by KB's-Slammed69; 08-20-2007 at 01:28 PM. |
Re: 20" Wheels..... what offset do I need?
im not sure what offset is mine, its been a while. but i know mine are the same as a factory 73 and up chevy 4x4...
Tot Roddin'
![]() In order to determine the correct offset is usually up to the owner or tire shop, and the type of wheel/tire combination in question. It depends on the wheels, the type of suspension (different rear axle, discs front/rear, and many other factors. You might find more information on the Suspension portion of the site, but you will get plenty of feedback here as well. Also, try a search for backspacing on 20" wheels and you will find many other posts on this same topic. Good luck on the search, I'm having the same problem... By the way... ![]() Also cflvulcan, love how the truck turned out! Love that color!
-Nate ![]() 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) Last edited by 72BlckButy; 08-20-2007 at 02:43 PM. |
You can search any of my threads and find all the information you need. I nearly beat this topic to death. Also try the suspention
1972 Cheyenne 402 LWB 2005 Silverado X-Cab 5.3L 2004 John Deere L120 20HP B&S |
Thanks for the help! I have air ride suspension, stock rear end, and disc brakes all around.
How do I post a pic? |
GM ONLY BABY!!!
I think it's +13mm or +18mm.
2 wrongs don't make a right, but 3 lefts do. 66 Chevelle Malibu 406ci, 573hp, 10.99@121mph 96 Chevy Silverado Z71 72 GMC 1500 Super Custom LS 6.0/4L65 on airride ![]() ![]() http://www.cardomain.com/ride/707879...mc-c-k-pick-up |
What width wheel are you going with? 8.5, 9.5, or 10.
