Old 08-21-2007, 10:16 AM   #1
SKELLEY
SKELLEY's Avatar
Speedometer Gear Leaks
I Have A 71 Lwb K10 With A 350 4sp Manual And A New Process 205 T/case. The Speedometer Gear Leaks Like A Siv (whatever A Siv Is?). I Took It Apart And There Is No O Ring Or Inner Seal Whatsoever. Are These Available Anywhere - Someone Help Me Please::
Sean
SKELLEY is offline   Reply With Quote
Old 08-21-2007, 10:36 AM   #2
woodridge
woodridge's Avatar
Re: Speedometer Gear Leaks
Two things that usually cause these to leak are over-filled gear box and or a worn housing or gear. If you noticed, the gear shaft is spiral cut and this constantly pulls the grease away from the cable end. Any wear will cause it not to work very well or not at all. The housing and gear should still be available from GM.
SEMA Network- Protect our Hobby!
71 C30 in pieces, starting to come together.
Click here for A Place For Tennessee Truck Enthusiest To Meet
woodridge is offline   Reply With Quote
Old 08-21-2007, 10:39 AM   #3
Aarons72s
There should be an o ring on the outer housing and a press in seal that the spedo gear slides thru. The o ring should be easy to find but you will have to go to napa or oreillys for the inner seal. I have had to replace both on my green and white with th350.
Aarons72s is offline   Reply With Quote
Old 08-21-2007, 11:20 AM   #4
timcos
Chief Honcho In Charge
timcos's Avatar
A sieve separates wanted/desired elements from unwanted material using a tool such as a mesh, net or other filtration or distillation methods
1992 1500 4x4 Shortbed
1984 Ford F250 Supercab Longbed 6.9L Diesel
1972 K10 Cheyenne Super Fleetside Short Bed - 350 - A/C
1971 VW SuperBeetle
1960 Wife
1984 Son
1986 Son
1989 Son
Previous Trucks
1967 C10 SWB (1980-1981)
1971 C10 LWB (1998-2004)
timcos is offline   Reply With Quote
Old 08-22-2007, 07:27 PM   #5
SKELLEY
SKELLEY's Avatar
Thanks, I Never Knew What A Sieve Was Or Ment! And Of All My Internet Search I Never Thought To Ck With Napa! I Would Rather Get The Housing And Gear From Gm - They Seem To Hate To Look Up Old Parts. Anything With Less Than A 17 Digit Vin Is A Pain! She Aint Overfull As It Will Lose 2 Qts In A Month! Yikes
Old 08-22-2007, 10:00 PM   #6
jerry moss
Born Psycho
jerry moss's Avatar
Somewhere In My Vast Inventory (aka-mess) Of Papers, I Have The Name Of A Company That Rebuilds Those Things. They're 35+ Years Old And Most I've Seen Leak At Least A Little Bit.
jerry moss
72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD
69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies.
73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog.
77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW
BRENTWOOD,CALIFORNIA
jerry moss is offline   Reply With Quote
Old 08-26-2007, 11:37 AM   #7
SKELLEY
SKELLEY's Avatar
I AM A LITTLE CONFUSED-IF IT IS SUPPOSED TO BE SPIRAL CUT THEN MINE IS WORN BEYOND RECOGNITION. IT LOOKS LIKE IT SHOULD HAVE A SEAL BUT NONE EXISTS. AND LAST - IF THE NP 205 IS THE BULLET PROOF T/C THAT EVERYBODY WANTS AND SO MANY ARE REBUILT AND ADAPTED TO QUADS THEN WHY CANT I FIND ANYTHING ON SPEEDOMETER GEARS (DRIVEN GEAR AND HOUSING) - DO THESE PEOPLE JUST CAP THEM OFF AND FORGET THEY NEED A SPEEDO? I AM SORRY FOR WHINING BUT THIS IS DIFFICULT. I HAVE NEVER RUN INTO A PART I COULDNT FIND FOR MY 56 BEETLE! Y'ALL HAVE GIVEN ME INSIGHT THOUGH AND I AM SURE WE WILL FIND THE ANSWER
Old 08-26-2007, 01:13 PM   #8
72freak
Rottenwood Garage Member
72freak's Avatar
Sean
I thought they were supposed to do that..........I have owned 150+ GM products and I think 149 of them leaked there.
2004 Chevrolet Suburban C1500
2001 Chevrolet 2500HD Crew 6.0
1999 Harley Davidson Electra Glide
1972 Chevrolet C-20 Custom Camper "Dump Truck"
1972 Chevrolet C-20 Suburban "Big Green"
1969 Chevrolet C-50 Wedge Hauler "Leonidis"
1966 C-10 2x4 short fleet 327 4 speed "Race Truck"
1952 Plymouth Cranbrook "Rican" (my grandfathers)
1931 Ford Model A Coupe "Black Beauty"
1930 Ford Model A truck "Club Cab" 4x4
Rottenwood Garage and Speed Shop.....where everything must be racy!
It's not just a hobby..It's a LIFESTYLE!!!
Thanks for nothing Barrett-Jackson
You cant fix stupid or teach accountability!
Time wasters, looky Lous and tire kickers are everywhere!
72freak is offline   Reply With Quote
Old 08-27-2007, 05:04 AM   #9
SKELLEY
SKELLEY's Avatar
I dont care about a little leak - but - man this thing loses 2 qts a month and I dont drive every day!
Old 08-27-2007, 10:53 AM   #10
Green Machine
Green Machine's Avatar
I've fought that gear leaking thing on many GM vehicles that I have had over the years. Seems that there are two style available. Gm used the ones without a seal on many manual transmissions. I guess they figured the heavier grease would not leak out ? (wrong). Get an adapter from a Chevy Turbo 350 automatic, the smaller style, (not the big 400 style), best to get a new one if you can. If getting a used one, check the inside bore for any wear, replace inner seal, put the clip back in over it and a new O ring on the outside. Get a new gear if it has any wear at all, might have a groove worn at the seal area, and you have done all that you can do.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
Old 08-27-2007, 01:01 PM   #11
mrein3
mrein3's Avatar
Or if you are a Gopher hockey fan, this is a sieve...
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 08-27-2007, 03:23 PM   #12
So.Cal.Super
It'll Buff Out!
So.Cal.Super's Avatar
Mine leaked untill I replaced the Gear itself. The trans shop pointed out the nice groove that had worn itself all the way around. no more leaks now.
"Instructions are just another mans opinion"
Become a Supporting Member
Man Card Rules
http://67-72chevytrucks.com/vboard/s...d.php?t=634550
72 Chevy Cheyenne Super 400 LWB
So.Cal.Super is offline   Reply With Quote
Old 09-01-2007, 08:25 AM   #13
SKELLEY
SKELLEY's Avatar
Well now, while surfing this site I found someone who had a link to a site that actually had the exact repair = see http://www.norcalbigdawgs.net/Gallery/album49
I dont think I am still losing gear oil - time will tell. Still drips but I think it is because the ratio adapter and speedometer cable were full of gear oil!
Thanks for all the help
Old 09-01-2007, 09:52 PM   #14
mfarmer
Good information....
mfarmer is offline   Reply With Quote
Old 09-02-2007, 03:08 PM   #15
Twistedsteel
Twistedsteel's Avatar
Sweet I gotta get me one. I just gave up puttin oil in mine, it's probably a couple quarts low too. I've tried everything to fix it. I can't wait, it'll be like havin a new truck again
Twistedsteel is offline   Reply With Quote
