08-21-2007, 11:07 AM | #1 |
New Member
GM Perf. Parts Serpentine setup
Has anybody tried using this Big Block serpentine setup from GM Performance Parts in their 67-72 (GMPP #12498733)? I'm in the process of putting in a 502 crate motor in my 72 suburban (with dual A/C) and was thinking this may be easier than trying to scrounge up all the brackets, pulleys, etc. for a big block. Maybe even cheaper at the end of the day!
I'm kinda wondering if it'll be difficult to adapt the a/c compressor and the alternator. Probably have to use R134? I'm pretty sure I can get the power steering pump to work. Any advice would be appreciated. Thanks! |
08-21-2007, 11:19 AM | #2 |
Re: GM Perf. Parts Serpentine setup
The only thing better would be if GM made that set-up for a short water pump
08-21-2007, 03:12 PM | #3 |
I put this set up on my zz4. It was very easy. The a/c lines will work, the power steering pump will need a cutom line made at local parts house cost me 35.00. other than that peice of cake. Looks clean and no more belt adjusting!
08-21-2007, 03:58 PM | #4 |
I have it on my 402 in my jeep...
I switched out my steering box to use a later model Chevy box. Was easy, this is the incorrect belt routing... Last edited by FormerMember; 10-04-2007 at 06:32 PM. |
08-22-2007, 12:01 PM | #5 |
New Member
Thanks guys, I think I going to go for it!
08-22-2007, 03:55 PM | #6 |
Watch the clearance for your radiator, the water pump pulley is super close with a long pump and the motor in the stock location. I kept my short water pump because of it.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
08-23-2007, 03:21 AM | #7 | |
thats the factory set up my engine came with. its a gen 5 454. it barely clears the rad. but its kick ass haha
here are some old pics
08-23-2007, 05:55 AM | #8 |
I put it on my 502 with the factory kit(pump,alt,pwrsteering pump,compressor). Biggest issue I am still working on is the clearance issue to the rad no room for a clutch fan and no room for electric fans. Right now I have a 12" and a 14" electric in front of the air conditioner coils and a 16" flex fan(no room for anything bigger) on a 2" extender. I am trying to make up a fan shroud to funnel the air better to the flex fan.
I just swapped the valve on the new pump with the old pump and all of the hoses to power steering worked.
72 longhorn c30 502BB/th400/fact air/4.11rear/ custom camper 72 bug(the better half's) under reconstruction 2009 HHR aqua blue 71 GMC k20 350/sm465 2009 Chevy hd3500 6.6 Victory Red crew cab dually Dave & Jeanne Last edited by dwaite72lnghrn; 08-23-2007 at 05:58 AM. Reason: additions |
08-23-2007, 06:46 AM | #9 |
Active Member
It's exactly what i used on my ZZ454...
"The Great State of Florida" |
08-23-2007, 07:37 AM | #10 |
Java Mechanic
Well.. it's about half the price of the same getup from Vintage Air --
http://www.hotrodsusa.com/store/frontrunner.html At $900 to $1700 for these setups .. I think I'll scrounge on my budget but I can certainly appreciate why someone with deeper pockets for their project might go this way.
Keith 11 Lincoln MKT -- Momma's wagon 13 G37xS -- middle age crazy car 68 C20 Fleetside -- RIP Decorating the whole town up at a cost of $27 .... |
08-23-2007, 08:44 AM | #11 |
Farm Truck
Kfreddy, I Noticed You Used Newer Motor Mounts, What Type Of Exhaust Manifolds Or Headers Did You Use. Looks Like It Was A Tight Fit.
1969 CST/10 1984 K5 Blazer 4x4 2016 Dodge Ram 2500 4x4 Mike Jersey Village, Tx |
08-23-2007, 10:38 AM | #12 |
New Member
I'm putting this on 4x4. It looks like you guys with tight fan/radiator clearance have 2wd. Doesn't the 4x4 engine crossmember sit farther back (2inches or so??) towards the firewall. So maybe no clearance issue on a 4x4??
Thanks guys. |
08-23-2007, 05:02 PM | #13 |
Cant they dont make a reverse flow short pump, serpantine setups run the pump on the backside of the belt so it spins backward, plus why would you want a short anyway limited water flow, if you coming into this century with the serpantine why not use a pump from thios century, chevy stopped using them in the 70's for a reason
1968 Short Fleet 350/700r4 http://67-72chevytrucks.com/vboard/s...d.php?t=249435 1997 Bagged XtdCab Vortec350/4L60e http://67-72chevytrucks.com/vboard/s...44#post2286144 1993 XtdCab Longbed 4x4 6.5Turbo/NV4500 "Daily Driver" 1985 Toyota XtdCab 4x4 22re/W-56/Dual T-cases, Doug Thorley Header, Homebrew front and rear spring packs, Tons of Mods to suspension and drivetrain, 35" boggers, coming soon ARB's and 5.29's, Possible 4.3/700r4 swap |
08-23-2007, 05:06 PM | #14 |
you can buy a conversion fitting from eaton for 4.50 at NAPA for this and keep your original line
08-23-2007, 05:07 PM | #15 |
Where did you find a reverse flow short pump and how did that work since they pulley wouldn't line up with the others
08-23-2007, 08:05 PM | #16 |
"See the U.S.A....."
Not "reverse flow" but "reverse rotation". The flow is the same direction as any old Chevy. Just to clear thing up.
1970 short bed fleetside 1949 all origional chevy 3600 1974 camaro Richmond , Texas(just S.W.of Houston) |
08-23-2007, 09:20 PM | #17 |
if you by the kit from gm performance it comes with it
08-25-2007, 03:22 PM | #18 | |
Still do they make a special pulley for short pumps? why would you want it due to limited flow capabilities? do they make a "reverse rotation" short style pump? again why why why? If your not going with a concours build why run the short pump and serpantine would be out of the question anyway
1968 Short Fleet 350/700r4 http://67-72chevytrucks.com/vboard/s...d.php?t=249435 1997 Bagged XtdCab Vortec350/4L60e http://67-72chevytrucks.com/vboard/s...44#post2286144 1993 XtdCab Longbed 4x4 6.5Turbo/NV4500 "Daily Driver" 1985 Toyota XtdCab 4x4 22re/W-56/Dual T-cases, Doug Thorley Header, Homebrew front and rear spring packs, Tons of Mods to suspension and drivetrain, 35" boggers, coming soon ARB's and 5.29's, Possible 4.3/700r4 swap Last edited by Scott68-93-97; 08-25-2007 at 03:25 PM. |
08-25-2007, 03:23 PM | #19 |
A short style pump thats what Im talking about clay68c10 said he kept his short pump how is what Im asking I know the pump comes with the kit
