08-21-2007, 11:16 AM | #1 |
help with a soft top
hey guys i have my hands full. when i bought this truck it came with a white soft top, all the bows, door window angle. thats it, i am missing both side rails, bow pivots,the top was never installed on the truck. i cant find out the make of the top, no markings or name anywhere. and the top isnt in bad shape, i was wondering does anyone have a idea the make of it and possibly if i can make it work has a digram of winshield snap locations, center bow pivot location, also need inside to insidebow measurements as center spacers for bows are missing also. thanks for any and all information.
08-21-2007, 12:30 PM | #2 |
SKINNY TIRES RULE!
Re: help with a soft top
I have the instructions for the Specialty Top Co (STC) fast track top on my computer. If you PM me your email address, I'll send it to you.
Most likely, the top is either a STC, Kayline or Bestop. If it is a Bestop, you may be able to still get parts. The other two are out-of-business. The bed rails should be fairly easy to make. A simple piece of "L" shaped aluminum should work, Drill holes to match the top mounting holes. The snap locations should just fall into place along the rails. The mounting brackets and locations will be the toughest thing to find. You may have to try to find a board member with a similar top and have them take some measurements. Good luck and post some pictures of your truck when you get a chance.
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
08-21-2007, 01:26 PM | #3 |
i know that i have called bestop with questions and was told that they did not make any in white. also that it should have had so markihgs or numbers, name if it was.
08-21-2007, 02:25 PM | #4 |
SKINNY TIRES RULE!
Bestop only makes black tops. Kayline tops had a small tag sewn into the seam above the rear window. STC tops have a logo printed on the rear window. There have been other tops made over the years, but I don't know any of those other manufactures.
Sent the instructions to you via PM. They are for the STC fastrac top, but it might give you an idea of how to install the top and what all is missing.
08-22-2007, 07:42 AM | #5 |
still need more help with soft top. i beleive it is a speacialty top. as i said i am fabing up everything. but i need to know center of bow pivots and spacing, also need to no what size to make side angles, base and hight. any help would be great,thanks scott.
08-22-2007, 02:45 PM | #6 |
is anybody running a specialty top on there truck right now that could give me some measurement, thanks scott
08-22-2007, 03:35 PM | #7 | |
Just need a couple more parts.
--------------------------------------------------- 1947 Studebaker M5 project to match the camping trailer. 1950 Chev 4x4 Pickup 1958 Shasta Airflyte Travel trailer (fresh restoration) 1971 C/10 Pickup(Frame off Restoration) 1972 K5 Blazer CST (Daily Driver & My Company Truck) 1976 Honda CB750 Bobber 1988 Jaguar XJ12 |
08-22-2007, 05:31 PM | #8 |
Post Whore
How soon do you need this information?
I have a used STC Fastrack that I recently bought that is uninstalled. Supposed to have all the hardware. I could get you measurements of the parts but I would be a little clueless on where each part goes since I haven't installed it before.
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
08-25-2007, 06:43 AM | #9 |
after i got going on making angle side brackets. my neibor and i strectched the top over the truck with variuos clamps and other tools. started streching and fitting, looking good. got stumped on bow pivots and door angle, where to weld loop on bed rail for door angl and window frame bracket, decided to take a break. looking at the top decided to clean with some vinull cleaner from the boat, only to find a little tag on the right rear corner of the top that said BESTOP, mind you i called bestop a couple of months ago and i was told that they never made a white top. after getting the bestop install guide, things started making sense. so i called bestop again and this time was told they used to make a white top years ago but not any more. but could still oreder a frame parts and they where in stock and on they way to the house. bought both bed rails,bow pivot kit,bow spaciers,window frame brackets and a couple of other things for about $105.00 delivered to th house. i will let you guys know it turns out in a couple of days. again thanks for any and all info.
08-25-2007, 09:27 AM | #10 |
Post Whore
Sweet, glad you're getting it figured out.
