08-21-2007, 01:14 PM | #1 |
Convert T221 transfercase to the 205
I was wondering if anyone else here has experience with this modification.? The PO on my truck had already did it and used spacers about 1 1/4 inches thick to drop the transfercase because of the difference in output height in the 2 styles of transfercases. It is a K-20 so it has the 2 piece rear driveline with the carrier bearing. I am assuming this was the reason for the drop.
08-21-2007, 03:15 PM | #2 |
Re: Convert T221 transfercase to the 205
ttt
08-21-2007, 03:38 PM | #3 |
Tool Addiction=Money Shortage
Try posting this in the 4x4 section you will have better luck.
Your post isn't very clear about what information your looking for. If you need a measurement of d-shafts, or distance below framerails, I can help my 67 k20 has been converted to a sm465 with a 205t/c. I can get you some measurments if you want. Nick
1967 K20 400TBI SM465/NP205 posi front, Detroit locker 4.56 rear Last edited by ND_guy; 08-21-2007 at 03:39 PM. |
08-21-2007, 03:50 PM | #4 |
Post Whore
I know the transfer case crossmember used with the Dana 20 transfer case and the NP205 transfer case are different. When I put an NP205 in place of the Dana 20 that was in my K5 I had to use spacers to drop the Dana 20's crossmember, otherwise the top of the NP205 transfer case hit the bottom of the floor.
I guessing that might be what occurs with the NP205 and T221 transfer cases. You can see the 1" spacer I used under the crossmember and there is also a set inside for the upper frame mount.
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 Last edited by Yukon Jack; 08-21-2007 at 03:53 PM. |
08-21-2007, 07:15 PM | #5 |
To put it simply, the 221 was a dropped output that ran off a different shaft than the direct output inline with the trans output. Approximately 3 inches lower I believe. That is what requires the lowering blocks.
