09-26-2002, 09:13 PM | #1 |
72 Cheyenne
Best gears for the quarter mile?
4:10 or 3:73?
09-26-2002, 09:22 PM | #2 |
that depends on your engines power band..if the motor makes it power from 3500-7000 then 4;10s or 4;56 would be the ticket, but if the motor is more in the 2000-6000 range I would go with 3;73s
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications click the clicky to join the site.... http://67-72chevytrucks.com/vboard/payments.php 67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44 Anderson,CA |
09-26-2002, 09:33 PM | #3 |
Gotta Startem Early
Sometimes if your engine makes gobs of low end torque (500 ft-lbs) around 2000, even 373's are a little too much. I wouldnt go below 350's though. Mr. Gasket has a really great program called Dragstrip 2000. It will give a pretty good idea of track performance if you know your engine specifics. You can change inputs and see the outputs on the screen.
67 SWB In Progress, one piece at a time, maybe 3 years I will be finished |
09-26-2002, 11:03 PM | #4 |
4.10s would be my choice after looking over your engine/converter combo.
Got torque? Last edited by 540 Stroker; 09-26-2002 at 11:07 PM. |
09-26-2002, 11:17 PM | #5 |
Both work good, it depends on your powerband and tire size.
09-26-2002, 11:18 PM | #6 |
72 Cheyenne
To tell the truth we haven't installed the 3:73 yet, they were supposed to go in a few weeks ago but I put it off ( I changed the signature ) 4:10 are better off the line but 3:73 are better after, true or no? I raced a new GMC truck a couple of days ago and he beat me bad off the line but I caught up to him in a few seconds and blew past him.
