Old 08-22-2007, 10:05 AM   #1
donzoidz
Big Block Engine Decode? HELP!!!
Hey guys I need some help trying to decode a big block chevy. I cant get to the back numbers it was a swap into a 64 truck and it is right up against the firewall. I have the numbers off the front of the block boss in front of the head if it helps. T 121 IIV 18L131634 Any help would be greatly appreciated. Please send your replies to socalhotrodz@aol.com Thanks so much.
donzoidz is offline   Reply With Quote
Old 08-22-2007, 10:10 AM   #2
1968SWBBigBlock
Active Member
1968SWBBigBlock's Avatar
Re: Big Block Engine Decode? HELP!!!
That does not look like a good number to me.
1968 SWB
454 + .040, 490HP x 540 FT pounds of Torque 10-1 Kb Forged pistons, recon rods w/ ARP wave loc bolts
781 heads Ported with 2.19/1.88 SSTvalves
Lunati 60204 cam, Micro Trol lifters,
Ported Edelbrock Performer Rpm manifold armor coated, Pertronix Triple Strike Ignition
Holley 770 Street Avenger carb,Headers armor coated
Built by Watson Ruppel Performance in Sarahsville Ohio.
Hardshift Tranny Built Turbo 350,TSI 10" 3000 stall
12 Bolt Eaton Posi 4.10 Richmond Gears moser axles
18.5" x 31" Hoosier Pro Street Radials
ET Classic 5 Wheels - polished
Power Steering, Power Brakes,Disc Brakes,Tach & Gauge Dash, Tilt,Factory Air (gone)
Custom Paint & Body Work
Special thanks to my wife, my son and my money tree
1968SWBBigBlock is offline   Reply With Quote
Old 08-22-2007, 11:40 AM   #3
Livrat
Member #1049
Livrat's Avatar
Is it possible that the third to the last letter is a "1" instead of an "I"?
If its "IV" instead, it appears to be a 1965 Impala 325HP 396 that came with a T400 behind it. does it have a "cannister" oil filter assembly or an aluminum adapter under a spin on oil filter?
Livrat is offline   Reply With Quote
Old 08-22-2007, 03:12 PM   #4
Ricks1971
Ricks1971's Avatar
If ya have some casting numbers you can tell alot better.
http://www.mortec.com/bbc.htm
Ricks1971 is offline   Reply With Quote
