![]() Join Date: Mar 2005
I-6 vs. v-8 trans crossmember
for those of you who have changed over your 6 cly. trucks to v-8 and move the manual tranny crossmember foward for the v-8 to sit in the correct position.the question is did you reuse your crossmember or us a v-8 cross member from a donor truck. i moved mine last night and it was not as straight foward as i thought it would be(thought i was working on a ferd)
Ever heard of Beech Island??
Re: I-6 vs. v-8 trans crossmember
I didnt do anything with my crossmember when I switched to v8. I just have the bellhousing crossmember. This is the only pic I found of it.
Oh you said the correct position. I am not sure about mine being in the correct position, but it works. Last edited by OlChev67; 08-22-2007 at 02:44 PM. Reason: forgot something |
Next project: 1970 K10
If you are reusing the I-6 engine stands, then it shouldn't have to be moved. If you switched to the V-8 stands, I would guess some people would just use an automatic crossmember, or an aftermarket crossmember since most all 3 and 4 speeds I've seen has the ability to be mounted from the rear, as is the trans in the pic above.
My truck was already swapped over to a V-8 when I bought it, using the original 3-speed manual trans in the original location, with the I-6 towers.
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE |
i wanted to move mine when i did the v-8 swap just to make it look factory.
yes glock35ipsc, i'm using v-8 stands and anything else i needed from a donor truck except crossmember and tranny. the original x-member seemed to work fine after some adjustments,i thought it would slide foward and bolt in with no problems. |
Questionable
the L6 and V8 trucks had totally diff't tranny crossmembers. V8 is flat and wide, L6 is half-round and skinny. the V8 xmember sits back about a foot from where the L6 does.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. Last edited by shifty; 08-23-2007 at 04:32 PM. |
I was wondering about that issue with manual crossmembers because it didn't look like it could move anywhere. Mine was riveted in too, the PO just cut out the crossmember with a torch when he put in an automatic.
That sounds like a real headache, but might be easier now that you know the V-8 member is a different part. Good luck!
_______________ Thomas '78 Silverado '74 Monte Carlo '47 Teardrop Trailer East Texas Classics Local Club |
Questionable
you can also grind out the old crossmember. that's what i did.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
