Old 08-22-2007, 10:11 PM   #1
BCOWANWHEELS
Wtb A/c Part And Radiator Mounting Part
I Really Need The Round Plastic Vacume Resivour That Bolts On The Side Of The A/c Housing Under The Hood By The Valve Cover From A 1971 Or 1972. Its Held On By 2- 3/8" Socket Head Screws And Has 2 Vacume Lines Going To It. One Line Goes To Intake Manifold And The Second Goes Thru The Firewall To Passenger Compartment. I Need One " Badddd "
Also Needed Is A Set Of 3 Core Radiator Hold Downs That Has Provisions For A Fan Schroud To Bolt To. I,am Going To Install A Schroud On My 250 I-6 And All Its Got Is The Metal Top Cover And No Provision For The Schroud.
Help Guys
Bob
I BELIEVE IN JOHN 3:16
BCOWANWHEELS is offline   Reply With Quote
Old 08-22-2007, 10:20 PM   #2
billsbowtie
billsbowtie's Avatar
Re: Wtb A/c Part And Radiator Mounting Part
bob i think i have found 2 rad. hold downs. will make sure tomarrow.
i have 67/72 chevy truck parts f/s.
billsbowtie is offline   Reply With Quote
Old 08-28-2007, 01:09 PM   #3
John Fabris
TOTY 2006
John Fabris's Avatar
Hi,
I have a set of upper and lower 2-3 core mounts including good rubber pads. $15.00 shipped
John Fabris
67 C10 SWB
John Fabris is offline   Reply With Quote
Old 08-28-2007, 01:12 PM   #4
roughedup72
roughedup72's Avatar
If the truck is still at the u pull it I can get you the vac. reservoir.if you havent already found one.
1972 chevy cheyenne 10,nothing special at the moment,Its a work in progress, Working on the engine, paint and body,engine, paint and body,now its the suspenion, ahh hell I'm about tired of working on it. Maybe it will be a rat rod.
roughedup72 is offline   Reply With Quote
Old 08-29-2007, 12:53 AM   #5
BCOWANWHEELS
roughedup72,
yes please i need one bad.
thanks
bob
