the redneck camper we bought
even has it own built in awing!!!!!!!
Re: the redneck camper we bought
just gonna change the blazer over to a full top on bought the whole set up for 200 bucks
K5Camper
![]() Join Date: Mar 2004
Good Score! Did you get the little caps for the tops of the door frames too? You'll need them to cover the ends where you cut your window frames off the doors to match the full top.
You at least got the two biggest parts of the puzzle. The roll bar should work, but the legs might need some added length due to the 73-75 rear floor being higher in front of the rear seat.
Rob Z. 1975 K5 350/465/205/D44/12b 4" lift on 35's- RIP 1991 K5 8.1L/NV4500/241/D44/14b FWC Camper |
#4 | |
Yep even got the little caps the door frame(4) and the plates that hold the front of the roof to the windsheild frame.Just a shame to cut the blazer up after just getting it painted |
K5Camper
All you really have to repaint is the window frame. Well and now another top. Just make sure to use a lot of masking tape and fresh blades when you commence to chopping the door frames off. The caps cover the edges pretty well, but it's best to make the cut as clean as possible.
Thanks for the tip there Zoomad75
#7 | |
Don't forget the bedrails. They will be the toughest part.
89 K5 Full Convertible 350/700r4 on 10 bolt 14ff 4:10 4 inch lift 36x15.50x15 M/T ATZ |
It Is What It Is,,,,
Cool job!
*79 C10 Short Box ST8 6 bang'r * *Lowered w/ 3" Control arms, 2" Lower Coils and 4" shackles and hangers W/ FLIP KIT *__--__* 79 C-10 project* .........................__ ..............._____ l __\___ ..............|_(O)_ |___(O) ] FAQ INDEX Thread The Kulture ![]() My Rat Den ![]() |
what kind of extra support did you guy add to the body once you cut the roof off?Or did you add the rocker boxes like the 73-75 ones?
#10 | |
#11 | |
thanks for the Info on the swap.I talked with a friend of mine last night(he a body guy)Figured 10 hours to swap it over.He a little mad cause we just painted it last may |
