Instrument Lighting
My lights are very dim with full on. I have not as yet checked the the bulbs but it looks like every instrument is lite. Do they make brighter buls or a way to get them brighter. Would I have to change the board?
Re: Instrument Lighting
Have you turned the light switch knob to brighten or dim them?
56 Chevy Bel-Air 2dr. HT (purchased new) 71 Chevy Cheyenne SWB PU (502HO) 65 GMC short bed step--work in progress and my gofer |
Active Member
![]() Join Date: Jul 2007
If after you do this, they're still too dim, it may be the switch itself. It's basically a rheostat and it may be defective. I'd try removing it and spraying it with CRC or similar and just moving it back and forth to see if it can wipe itself clean...
Dave's not here, man
I agree with what has been mentioned above, and you can also try painting the metal that sits behind the plastic lens. I painted mine white and it really helped to brighten everything up. Here's a link to FAQ that shows what I'm talking about.
http://67-72chevytrucks.com/vboard/s...d.php?t=198705
- 2014 VW Jetta - 2015 VW Jetta - 1966 Ford F-250 |
its all about the +6 inches
stock, the lights are dim. Period.
I recomend taking it all apart, and anything you see that is that nasty shade of green... paint it white. That'll help more than bulbs alone. Then you can get 168 bulbs instead of the 194 bulbs that are in there. If THAT ain't enough, you'll have to go LED. Byrd (i think that's how you spell his screen name) sells awsome ones at a good price. |
What do you mean by that? Type of bulb?
68 Camaro - 327 Original Red on Red Car 69 GMC LWB - Built 350 a Blast To Drive 69 GMC LWB - "Green Machine" One Family Truck 70 Mercury Marauder - Future Project |
that's the number given to that kind of lamp. The 194 lamp is a wedge base, peanut shaped bulb with 1.5 candle power... the 168 is the exact same, but 3 candle power.
Self-proclaimed LED man
if you still cant get it fixed, there are companies that manufacture led 194 bulbs that fit in our dashes. They shine very bright even when the knob is turned to dim. Just an idea.
Justin
My LED Website My Photobucket Album of LED's Ask me about hand-made custom L.E.D brake and reverse lights. <- LINK I also do LED: -Third Brake/Cargo -Brake (truck and burb) -Reverse (truck and burb) -67-68 Front Turn Signals -69-70 Front Turn Signals -71-72 Front Turn Signals -GMC Front Turn Signals I can also do custom lights for other vehicles....i did a set for a AMC Gremlin once ![]() Norwood Survivor |
