Old 08-23-2007, 12:11 PM   #1
1970 CST Short Wide
Senior Moment
1970 CST Short Wide's Avatar
Detroit Lockers - Which one
I was thinking about a Detroit Locker, then I saw this
"Detroit Trueloc"
Anybody have any experiance with this one or for that matter any Detroit Locker.
Look here
http://www.eaton.com/EatonCom/Produc...trac/index.htm
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN
2013 GMC PU, Oldest Son
71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son
2019 GMC Diesil Dually. Youngest Son
2017 Toyota SUV Daughters car
2018 Traverse , Wife’s Ride
Pittsburg Ca
94565
1970 CST Short Wide is offline   Reply With Quote
Old 08-23-2007, 12:19 PM   #2
cdowns
cdowns's Avatar
Re: Detroit Lockers - Which one
have no idea what a detroit truloc is i suspect an inexpensive lobudget posi of some type
i've run a number of the original detroit locker performance rears they are an acquired taste but they are pretty stong and holdup to alot of abuse for true hardcore oldschool performance applications
Old 08-23-2007, 12:45 PM   #3
Ackattack
Ackattack's Avatar
I know in the jeep world the Detroit Lockers are among the best of the automatic lockers and I know a lot of guys that run them. I don't think I'd want a locker for a street application though.
I have a detroit truetrac limited slip in the front of my jeep and it works fine.
I also have an eaton limited slip in my 72 and it has worked great! BTW eaton makes detroit lockers.
Ackattack is offline   Reply With Quote
Old 08-23-2007, 01:14 PM   #4
1970 CST Short Wide
Senior Moment
Go here to see it. New I guess
Pittsburg Ca
94565
Old 08-23-2007, 02:12 PM   #5
cdowns
cdowns's Avatar
interesting// the thing that would steer me away from the truloc is that it is nonserviceable i'd rather stick with the original eaton posi or with higher horsepower applications the detroit locker both longtime tried and true rod material
Old 08-23-2007, 04:04 PM   #6
1970 CST Short Wide
Senior Moment
Yah I found it very intriguing also. I only take this truck out to play on week ends so a tried and true Detroit Locker would be OK with me. My son works at a parts house so the Locker would run me ~$500. This new “Truetrac” would run me ~$450 so it s no big deal.
I just wanted to know if anyone’s used one and what they thought of it. I’d hate to install it and then have the 454 eat it for lunch
Pittsburg Ca
94565
Old 08-23-2007, 10:30 PM   #7
BCOWANWHEELS
I Hope You Have Alot Of $$$$$$$ For Tires If You Install A Locker And On Wet Roads Its Easy To Spin Out. Also Gas Milage Goes Way Down......
I,ve Got Em And Run Em Alot. Oh Yea When They Ratchet You,ll Think The Rear End Broke.
I BELIEVE IN JOHN 3:16
BCOWANWHEELS is offline   Reply With Quote
Old 08-24-2007, 08:42 AM   #8
mplex2000
mplex2000's Avatar
Yes! A Detroit Locker is the way to go. I have one sitting in the garage with a new set of 3.73s that are just waiting to see some torque.
mplex2000 is offline   Reply With Quote
Old 08-24-2007, 08:42 AM   #9
There`s only one Detroit Locker,btw.Not tryin`to be contrary,but have alot of experience with them and run one in my driver.Tires last just fine if you drift turns and keep it light on corners and turns you can`t drift through.Rotating tires helps,too.They`re not quite a spool and have a bit of give over those(ratchet action).I love them and snatch them up when I see them.Haven`t noticed any mileage difference at all on any trucks I`ve had.They`ll scearch just enough to let someone know what you got if you`re showing off and they know what they`re listening to.I like to give about three little ones like I can`t help it when I show off.You know because the engine isn`t even workin`.But,that`s how easy it is to control.It`s all in the right foot.
Old 08-24-2007, 09:19 AM   #10
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
When Currie built my rear end, theytold me that if I was doing any burnouts, a locker would be my choice. (its a durability issue) Otherwise a tru-trac or limited slip would be the way to go (better for road course work because of a more gradual (clutch action rather than locker action) operation.
Tom Vogel is offline   Reply With Quote
Old 08-24-2007, 09:25 AM   #11
jkade
jkade's Avatar
Originally Posted by 1970 CST Short Wide View Post
I have one of them in my 86 k10 and I did a burnout with the 35's and I broke it. Called them up and you cannot buy parts for them I ended up and bought one for the front off ebay and used the parts in it to fix mine. I have a eaton posi in my 67 and I think it would be just as good for a street truck, I think I paid $180 for it off ebay brand new. JM2C
jkade is offline   Reply With Quote
Old 08-24-2007, 05:08 PM   #12
BCOWANWHEELS
i have a detroit locker in my kaiser jeep m715 army truck and it has a dana 70. its not...... and road friendly setup. if your on the gas its locked up period.....
Old 08-25-2007, 07:55 AM   #13
Nothing road friendly about an M715,that`s for sure,right?Not arguing,just saying driving technique compensates the matter and makes it a roadable diff.At least that`s how I feel from my experience in the vehicles I`ve run them in.They can break,too.But doing burnouts on pavement with big tires can certainly help.I twisted a short shaft in two on a truck with divorced t-case.That shaft only has enough tube to conect the two ends,like 3".It twisted like a sardine can lid opens.I had been doing burnouts on "The Circuit" in town before ending up running around a motocross track,then playing around in a sediment pond trying to get stuck.I was climbing up out of there and,"Wham!!!!thud thud thud thud...",we were suddenly drifting back into the muck.That truck had 14.50/37s and a Locker.The Locker survived.Ever replace a driveshaft lying in a silt pond(hung over?)?Yeah.that`s what it`s all about!
