08-23-2007, 03:35 PM | #1 |
clutch linkage in a '67
Can anyone tell me if this is a stock configuration for my clutch linkage, or did someone mess with it? Looks like someone cut it and welded it to me, but I'm not sure what stock is suppose to look like. It had a 3 speed in it from the factory, now it has a 4 speed.
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD Click here to support the board Philippians 4: 6-7 |
08-23-2007, 10:18 PM | #4 |
Re: clutch linkage in a '67
Is that a piece of rebar next to it? If it is it's a good chance it's been molested. Sorry I don't know very much about the linkages. I did just pick up a 67 myself and it has a 4 speed not sure if it looks like that though. I'll look tomarrow and maybe snap a pic.
Albie |
08-24-2007, 03:34 PM | #5 |
lol! no, it's not, but I'm not sure what it is. Anybody know if the clutch likage has been modified or not?
08-24-2007, 03:59 PM | #6 |
The "rebar" is either the spedo cable tube or the parking brake, my guess is parking brake. The linkage on my 70 comes straight out with no bends. I bet the other end of the piece that I drew the arrow to is bent towards the drivers side. On mine it is straight. Looks like it was a 3 on the tree like mine. Hope this helps.
“If you don’t have time to do it right now, how will you ever find time to fix it.” - author unknown '70 SWB Step-Side (More rust than metal) |
08-24-2007, 04:00 PM | #7 |
TOTY 2006
The rebar looking thing is actually the ebrake cable.... Don't know about the clutch pedal linkage, looking for other pictures to campare with....
Is your shifter on the floor now? As the shifter rods are not on the column... |
08-24-2007, 04:10 PM | #8 |
Yeah, it's a four speed on the floor. Just trying to figure out what the P.O. did.
08-24-2007, 04:12 PM | #9 |
I just ran out and snapped a couple pics of mine. Reminds me I need to get a cotter pin to replace that nail. The duct tape is just there to keep cold air off my nuts in the winter
08-24-2007, 04:13 PM | #10 |
TOTY 2006
Here are two more pictures from the board here that appear to show the same clutch pedal rod....
08-24-2007, 04:16 PM | #11 |
Hmmm... makes me wonder if mine is wrong or if there is just that much difference between the 67 and 70.
08-24-2007, 05:22 PM | #12 |
member #16
Could it be 6cyl v 8cyl?
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors http://www.flickr.com/photos/1745471...7602865984234/ |
08-24-2007, 06:02 PM | #13 |
I am a Referee of life.
Lated,I can give you incentive to get the cotter key.I bought a truck and it had the nail fix like on yours.Worked real good for about 2 years(actually I never even thought about it).One afternoion I shifted into third on the highway and the clutch felt somewhat mushy.No big deal I'll check it when I get to the exit a couple miles down the Interstate.When I pulled over and shut down the engine I got a cloud of smoke.The ball pivot had snapped off and the clutch linkage shifted,causing the bell crank(the levered pivot) to lay against the oil filter with the nail point into the tin.The oil had pumped out a little at a time and the engine never ran again.When I replaced the engine I also repaired the oil guage.
So...Go Get a danged cotter pin!!!!
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
08-24-2007, 06:07 PM | #14 |
Junior Member
dan42- My 68 with 3 on the tree is the same as yours. Even the weld is identical.
'63 C10 lwb flatbed '66 C10 lwb stepside '68 C10 lwb stepside (parts) '68 C10 lwb fleetside (17 yr old son's ongoing project) '03 HUMMER H2 (wife's) '06 3500 flatbed liftgate (My work truck) |
08-24-2007, 06:09 PM | #15 |
Active Member
I've got a 68 GMC 250 with 3 speed and the clutch rod is straight, like the one in "Lated's" picture.
I also have a 69 Chev that had a 250 and a 3 speed and it was also straight. |
08-24-2007, 06:20 PM | #16 |
Junior Member
68gmsee's are straight on his 6 cyl's. Mine is a V8, maybe thats the difference.
08-24-2007, 10:21 PM | #17 |
Yeah, that's probably it - straight on the sixes, crooked on the eights.
