![]() Join Date: Aug 2005
Attaching Trim With Adhesive?
I'm thinking about welding up all the trim holes and using something similar to what EO's now use for attaching the trim. Seems like it would just make life much easier when it comes time to line it all up, and prevent any possible leaks. Opinions?
Next project: 1970 K10
Re: Attaching Trim With Adhesive?
When I as building van conversions we use 3M double sided adhesive tape that is about 1/16" or so thick. You had better have it in the right place, cause it was a biatch to get off. Whatever you had to take off was destroyed in the removal process. I wouldn't hesitate to use it on your Tahoe trim.
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE |
body shops use 3m double stick tape, i think its like 30 bucks a roll
Justin 1970 c/10 short wide bed WTT 1970 chevy front end for 67/68 chevy front end WTT 2 15x10 american racing outlaw 2 wheels for 2 of the same in a 15x7 or 15x8
Oh, I about forgot. If you do go that route, be sure to get 3M's adhesion promoter too. It just insures the stuff will not come off.
I bet I would have to use two layers or something thicker on the lower/side trim because of the deep roll on the edges.
its all about the +6 inches
I've lost a few longhorn badges, custom badges, and one CST 10 badge to the 3M tape, and the 3M glue. I would consider it for the light weight trim on the bottom of the truck body, but not the steel stuff.
![]() Join Date: Oct 2005
They make clips for the lower mdgs that use dbl side tape, but once it is on the thickness of the tape and clip don't allow it to sit completely flush with the body.
3M does make a thinner dbl sided tape that will help. I used "threaded" style clips on the ends of my lowers and then used clips with the skinny 3M tape. My biggest concern with using tape all the way around would be the mouldings at the front edge of the door. If they lift a little, they may catch on the fender when the door is open and screw something up.
72 Cheyenne SWB Fleet Nut & bolt frame off in progress...99.9999% - supercharged 383 - 4 wheel discs - relocated fuel tank - ![]() My Build Thread |
Sounds like that might work out well, gotta remember that
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
