Old 08-23-2007, 04:34 PM   #1
shifty
Questionable
shifty's Avatar
How to replace?
I need to replace the spot-welded piece shown below.
I am certain that nobody makes a re-pop of this, so I'm going to ask: What is the easiest way to replace this? I mangled this section of my firewall being a stupidass, cut through the support structure, tried to fix it and screwed it up worse in the long run.
If nothing else, what are the differences between the 67/68 and the 69-72 trucks in this area?
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 08-23-2007, 05:44 PM   #2
jaros44sr
jaros44sr's Avatar
Re: How to replace?
Looks simple and strait forward if you have a welder. Just locate and drill out existing spot welds and back fill with weld. Use zip screws to hold in place or clecos... J.
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 08-23-2007, 05:53 PM   #3
shifty
Questionable
shifty's Avatar
Re: How to replace?
that's what i was planning. looks like the front clip is coming back off. meanwhile, where the heck can you get a clean replacement for this piece?
Old 08-23-2007, 07:07 PM   #4
LockDoc
The Older Generation
LockDoc's Avatar
Re: How to replace?
I got rid of all my junker cabs or I would send you one.....
lockDoc
Leon
Old 08-23-2007, 08:19 PM   #5
krue
Designated A-hole!
krue's Avatar
Re: How to replace?
Post up on the parts board, it shouldn't be that hard to find. It's gonna be a few weeks before I get that far tearing down my parts truck or I'd send you one for nothing. (assuming mine's rust free, which isn't a safe assumption at all.)
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 08-23-2007, 10:15 PM   #6
Bob Moore
Re: How to replace?
Shifty - you say this is screwed up. What is the problem? Can you show a better(or worse) picture of the damage? Is this all related to the hydralic clutch linkage?
67 C-20 LWB, tilt, speed alert,
vac, 454, T400
67 C-10 SWB, factory air with
more to follow
Bob Moore is offline   Reply With Quote
Old 08-23-2007, 10:40 PM   #7
shifty
Questionable
shifty's Avatar
Re: How to replace?
The one in the picture isn't screwed up.
I won't post a picture of how badly it's damaged because, quite honestly, I am too embarassed to show it.
Basically, I warped the entire engine-bay side of the firewall near the steering hole. I also shredded the brace pictured above.
Old 08-23-2007, 10:45 PM   #8
67ChevyRedneck
67ChevyRedneck's Avatar
Re: How to replace?
^No more drinking and working on the truck
That sucks. I've done a couple things to my truck I refuse to post due to embarrassment as well. And some I won't even tell my pops about 'cause he'll laugh at me
Live and learn man
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 08-23-2007, 10:46 PM   #9
72armyswbtruck
72armyswbtruck's Avatar
Re: How to replace?
Shifty, don't be embarassed. We have all done more damage then we intended to.
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!"
72armyswbtruck is offline   Reply With Quote
Old 08-23-2007, 10:50 PM   #10
shifty
Questionable
shifty's Avatar
Re: How to replace?
Can anyone with multiple year ranges of trucks break out a tape measure and compare the difference in size between the 67-68 and 69-72 in this part of the firewall, please?
Do most of the bolt holes line up? (Thanks, if you can do this, and thanks ten times more if you can post pictures of bare firewalls from the INSIDE )
You do live and learn, but ... if I cut my cack in my zipper while takin' a leak, I damned sure wouldn't tell you guys about it
Sad part is, I was completely sober when I did it.
Old 08-23-2007, 11:44 PM   #11
shifty
Questionable
shifty's Avatar
Re: How to replace?
i just went down and looked at it again. I don't think it's as bad as I was thinking. I just need to figure out how to get the ripple out of the engine bay side. I need to measure it all out and see if it will do what I want or not. I suppose I could weld a bracket over the rippled metal on the other side.
Old 08-24-2007, 02:28 PM   #12
LockDoc
LockDoc's Avatar
Re: How to replace?
-0
Shifty,
Here is a picture of a '70 GMC (Blue) and a '70 Chevy (Yellow) firewall.
These two look the same to me.
Lockdoc
Leon
