Old 08-23-2007, 11:24 PM   #1
tab a
Broken rocker arm
1972 350 with lots of miles that burns lots of gas, and oil. Oil pressure is decent when moving, but pretty low at idle. Recently developed a knock that goes away when the 2nd spark plug wire on the right, is shorted. Pulled the valve cover and found the base of the 4th rocker arm broken. Pushrod looks straight. Same noise with the broken arm removed.
1. I'm thinking I need to pull the pan and look at that rod/journal?
2. Can the pan be pulled with everything else in place? Auto tranny.
3. Is a broken arm typically of symptom of ??????, or just old age?
4. Is it possible to buy a single rocker arm, to replace the broken one?
Thanks!
tab a is offline   Reply With Quote
Old 08-24-2007, 12:07 AM   #2
ckhd
ckhd's Avatar
Re: Broken rocker arm
1) I wouldn't yet
2) I think you have to at least lift the engine some to get the pan to clear
3) They fatigue after a while
4) I'm pretty sure you can get just one. If one has fatigued, good chance others are getting there.
The reason I answered that way on 1 is that the fourth one back means that the "second from the front" isn't working. Replace the rocker, then decide if you still want to pull the pan. A rocker replacement is cheap and easy, while pulling the pan is a pain in the butt.
my 2¢ - t.i.o.l.i.
Bowen
1968 K20 fleet
1969 K10 swb fleet
1972 K10 Suburban
1972 C10 lwb step
1992 K1500 'burb
1995 K2500 'burb
1997 C1500 'burb
1999 K1500
2000 K1500 'burb
Why do I own so many Suburbans?
ckhd is offline   Reply With Quote
Old 08-24-2007, 12:09 AM   #3
ckhd
ckhd's Avatar
Oh, change the oil if you're not going to pull the pan. There may be some metal fragments floating around in there.
my 2¢ - t.i.o.l.i.
Bowen
1968 K20 fleet
1969 K10 swb fleet
1972 K10 Suburban
1972 C10 lwb step
1992 K1500 'burb
1995 K2500 'burb
1997 C1500 'burb
1999 K1500
2000 K1500 'burb
Old 08-24-2007, 12:14 AM   #4
st1x10
st1x10's Avatar
Single rockers can be bought. I would replace and then change the oil like above. It might be ok and then if you find a problem you only replaced a rocker that you were going to have to replace anyways. So no wasted money.
1970 Chevy C10 "Under Construction"
2002 Chevy S10 V6
st1x10 is offline   Reply With Quote
Old 08-24-2007, 12:39 AM   #5
72armyswbtruck
72armyswbtruck's Avatar
To pull the tranny pan on our trucks depends on wether or not the transmission cross member was bolted on or riveted on. If it was bolted on then you can with some work unbolt the crossmember and then remove the tranny pan, I would at the very least drain the oil replace the pick up and clean out the screen. Good Luck
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!"
72armyswbtruck is offline   Reply With Quote
