Old 08-23-2007, 11:27 PM   #1
Alberta Newbie
Motor isn't what I expected
Hi everyone, can you help me out with ID-ing this motor? I've been trying to figure out the horsepower, and now I'm not even sure I know the size.
It's in a 1972 GMC 3/4 ton, which I was told was original and only had 45,000 miles on it. But now that I started looking I found a plate that says it was rebuilt.
Model XC120087
Serial X31791
Bore 040
M 01 T 01
Engine Rebuilders Ltd.
The VIN says TCE2421522076 and the SE (?) is FT0705638. The plate in the glove box just says 350 CID V8.
Any help greatly appreciated...
Alberta Newbie is offline   Reply With Quote
Old 08-23-2007, 11:35 PM   #2
BCOWANWHEELS
Re: Motor isn't what I expected
Well Its Bored .040 Over
I BELIEVE IN JOHN 3:16
BCOWANWHEELS is offline   Reply With Quote
Old 08-23-2007, 11:43 PM   #3
Alberta Newbie
I'm pretty new at this, guess I should have googled it. I was hoping the numbers would help me figure out what the horsepower of the motor (and maybe the compression) would be?
Old 08-23-2007, 11:57 PM   #4
Ole Blue 68
Ole Blue 68's Avatar
Hey Newb,
Do you have a casting number?
Ole Blue 68 is offline   Reply With Quote
Old 08-24-2007, 12:00 AM   #5
quickpm
Junior Member
quickpm's Avatar
You can figure out if it is really a 350 block if you get the casting number off the back of the block. The numbers are easy to see, they are about 1/2" tall. You can get stock head specs with the casting number on the heads. If it's been rebuilt, the sky's the limit. Heads could have been worked on, different size valves put in, ported, etc. Depending on the combustion chambers, head gasket thickness, and whatever kind of pistons they used (flat top, dished or domed) makes the compression ratio. The cam also greatly determines the power band. You may either have to dyno it or call Engine Builders, ltd to see what kind of motor they built.
I've been burned a couple times on a "350" that turned out to be a 305. You think I'd have learned the 2nd time. You can't tell from the outside. You have to run the numbers (with a book or google) or you have to pull a head and measure the bore size. It is really aggravating. I honestly think the 2nd guy didn't really know what he had (he was taken by someone else), but still.
72 C10 Long Bed, Vortec 350, Muncie M20, 3.73 Posi
79 Camaro, Vortec 350, Muncie M21, 3.90 Posi
07 BMW 328i, Wife's
quickpm is offline   Reply With Quote
Old 08-24-2007, 12:02 AM   #6
Ole Blue 68
Follow quickpm's advice and then you can look up the casting number at http://www.mortec.com/castnum.htm
Old 08-24-2007, 12:11 AM   #7
Alberta Newbie
I couldn't find it, so I thought they covered it with the rebuild plate. But a little work with a wire brush and I found it
K0312T4U
P.S. Thanks for all the help, I'm off to mortec!
Old 08-24-2007, 12:35 AM   #8
72armyswbtruck
72armyswbtruck's Avatar
Welcome Newbie
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!"
72armyswbtruck is offline   Reply With Quote
Old 08-24-2007, 12:51 AM   #9
quickpm
Junior Member
quickpm's Avatar
K0312T4U
I'm pretty sure casting codes are all numbers. Look here (hopefully this works):
It is on the driver's side rear on top. 460776 for this one. 305 POS. If you do have letters, I haven't seen that before. (Of course I'm not the de facto expert, either).
07 BMW 328i, Wife's
Old 08-24-2007, 01:48 AM   #10
brak
brak's Avatar
Originally Posted by quickpm View Post
I'm pretty sure casting codes are all numbers...
The code on the rear of the engine is all numbers, but if you look at the front of the block (passenger side, directly above the waterpump), there is a flat pad which has an engine code, and a partial vin. this Code always starts with a letter, and the code works as follows...
Engine ID Code Example: V0107CLJ - (V = Plant, 01 = January, 07 = 7th Day, CLJ = Engine Suffix Code)
Newbie, are you sure the last three in the code is T4U? I can't find that code (although my resources are limited) but i see a TAU which would be:
TAU = 1970 350 m/t 255hp 4bolt C-10
EDIT--> I forgot to mention, i usually look engines up using the info on NastyZ28.com. Mortec's site gives me a headache, and i can't ever find what i'm looking for
2003 GMC Sierra 1500 WT
1995 Nissan Hardbody
2016 Hyundai Veloster Turbo
DC2 (SW/AW) Clyde W. Harvey USN
"Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery" Winston Churchill
brak is offline   Reply With Quote
Old 08-24-2007, 07:59 AM   #11
quickpm
Junior Member
quickpm's Avatar
Sorry, I all but forgot about that pad. The place I always buy my shortblocks always scratches that off clean.
07 BMW 328i, Wife's
Old 08-24-2007, 09:59 AM   #12
WorkinLonghorn
WorkinLonghorn's Avatar
Mine too,but I think that happens when they "deck" the blocks (?).
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, stereo speakers, 2nd owner, Work-Truck supreme.
WorkinLonghorn is offline   Reply With Quote
Old 08-24-2007, 10:27 AM   #13
Alberta Newbie
Thanks everyone!
Yes, I found the number on the passenger side on the front of the block. I could barely read the numbers, so I'll bet it was an "A"; I'll double check tonight.
Old 08-24-2007, 02:20 PM   #14
Ole Blue 68
Definitely a possibility since this engine was rebuilt.
