08-24-2007, 01:41 AM | #1 |
Need Part Number For A/c Poa Valve
I,am Looking For A New Poa Valve And From What I Can Tell There Is Only 2 That Were Used By Gm 15-51 And 15-52. Which One Is Correct For A 1972 Chevy Tk ?
Thanks Bob
I BELIEVE IN JOHN 3:16 |
08-24-2007, 07:53 AM | #2 |
Re: Need Part Number For A/c Poa Valve
I believe they don't make them any more. I'd scour the yards for a POA then test it before you install.
You can find some good information here: http://www.autoacforum.com/messagevi...AR_MSGDBTABLE=
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
08-24-2007, 08:21 AM | #3 |
Old member
08-24-2007, 05:04 PM | #4 |
i need the factory part number, which is it 15-51 or 15-52 ?
bob
08-24-2007, 08:35 PM | #5 |
Delco 15-51 is the correct POA valve for a '67-'72. I have been told that a 15-52 will work with a little modification, but I have never tried it.
1967 GMC CM-2500 Camper Cruiser, 351E V-6, NP 435 4 speed, Dana 60, and factory A/C. 2012 GMC K-3500 WT regular cab, 6.0L Vortec, 6L90. |
08-24-2007, 09:03 PM | #6 |
Thanks Bob B
