Old 08-24-2007, 09:52 AM   #1
gotchevys?
gotchevys?'s Avatar
Drum brake help and 14 bolt ID
A friend of mine has a 72 3/4 ton 4wd with an Eaton rear. It is the Eaton with the hard to find narrow drums and as luck would have it, one of the drums is bad. Do any of you know What parts i would need to swap out the drums for the wider ones? I also have a 14 bolt that I could swipe the brakes off of. Will they work? The 14 bolt is in a parts truck that I'm pulling the engine from for a customers car. It has a 14bolt under it but it looks really narrow and it doesn't appear to have been shortened. It has dual wheels under the bed.
I took a few pics can you guy tell me any thing about this 14bolt?
www.fatdaddieshotrods.com
gotchevys? is offline   Reply With Quote
Old 08-24-2007, 02:43 PM   #2
Yukon Jack
Post Whore
Yukon Jack's Avatar
Re: Drum brake help and 14 bolt ID
I imagine that 14 bolt came from a cab and chassis truck given how narrow it is.
Have you given any thought to converting the Eaton to disc brakes? Blackbirds Customs has a kit to do that. I believe it is Boardmember drink2mny who works there and could tell you about it.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 08-24-2007, 03:34 PM   #3
1969k10stepside
I agree with Yukon Jack---The 14 bolt is from a cab/chassis truck so it has a narrower rear axle than a normal 14 bolt.As for the brake parts,can't help.
1969k10stepside is offline   Reply With Quote
