Old 08-24-2007, 03:27 PM   #1
crossy
Oh,you can't buy that new
crossy's Avatar
Need answer ASAP- 6 lug to 5
if you have a donor 5 lug 71-72 2wd in front of you, and want to swap out your 6 lug front end what is the easiest way. will just a spindle swap work out? thanx, crossy
"been there, done that, ruined the T-shirt".
2007 LBZ GMC Sierra, ECSB
2006 LM7 RCSB Silverado
98 Vortec project.
94,3500,6.5L 4L80
81 SWB GMC POS finally gone
73 Pinto, stock, w/CragarSS's-eww
LOTS of Cummins trucks.
crossy is offline   Reply With Quote
Old 08-24-2007, 03:52 PM   #2
sneakysnake
It's a catastrophic success.
sneakysnake's Avatar
Re: Need answer ASAP- 6 lug to 5
I think its easier to swap the whole cross member. The spindles arent a direct swap and you have to change A arms,tie rods,pitman. Where as 12 bolts and brake line and the whole thing rolls out.
sneakysnake is offline   Reply With Quote
Old 08-24-2007, 03:55 PM   #3
John Fabris
TOTY 2006
John Fabris's Avatar
Do a search on here. There are many combos, using the entire assembly is one, or replacing the outer tie rods, upper and lower ball joint and spindle is another way...
John Fabris
67 C10 SWB
John Fabris is offline   Reply With Quote
Old 08-24-2007, 03:58 PM   #4
crossy
crossy's Avatar
thanx, that's all i needed to know to tell a guy that wants my 5 lug front crossmember.
A search turned up SOOOOOOOOOOOOO many things unrelated with just the keywords that it cornfused me. thanx again, crossy
98 Vortec project.
94,3500,6.5L 4L80
Old 08-24-2007, 04:04 PM   #5
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
About 10 bolts and the entire crossmember is out. That seems to be the easiest way, and the quickest way, to me.
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
