Old 08-24-2007, 06:23 PM   #1
satin64
satin64's Avatar
my 64 gmc build,lots of q's??and pics
rusty rocker panel
im sure these aren't stock,right?
im assuming the round end should go to the positive side of the battery?
and this mess is???only one wire is connected to anything.
whats missing here?and what are these parts?can they be done away with?
thanks for the help in advance
satin64 is offline   Reply With Quote
Old 08-24-2007, 06:48 PM   #2
Stepside65
Still Truckless!
Stepside65's Avatar
Re: my 64 gmc build,lots of q's??and pics
Good luck with it man... Looks like it might be time for a rewire.
~James
Truckless
2009 Hyundai Sonata<~~Wife's sedanomatic
1997 Nissan Pickup Father-in-law's tonka toy I am forced to drive
Founder of The 60-66 Club
Tutor Et Ultor
Stepside65 is offline   Reply With Quote
Old 08-24-2007, 07:07 PM   #3
hewlett2002000
hewlett2002000's Avatar
the pic where the alternator is, the flat black connector with 4 wires in it goes to the regulator, which should be on the drivers side on the radiator support. that single wire i think should go to the horn, which should also be located by the regulator. my truck has the painless wiring harness with a few custom touches to the wiring but heres a few old pics of mine with the stock wiring. good luck.
john
http://i226.photobucket.com/albums/d...6/100_2209.jpg
http://i226.photobucket.com/albums/d...6/100_2208.jpg
Respect:
1. A feeling of appreciative, often deferential regard; esteem.
2. The state of being regarded with honor or esteem.
3. Willingness to show consideration or appreciation.
When you fail to show consideration to others values you are showing disrespect.
hewlett2002000 is offline   Reply With Quote
Old 08-24-2007, 07:11 PM   #4
satin64
satin64's Avatar
theres no way that flat plug could reach to the drivers side.if the alternator is internally regulated could this be why its not plugged in?if so how do you tell if the alternator is internally regulated or not?
Old 08-24-2007, 07:31 PM   #5
19GMC63
19GMC63's Avatar
usually the 2 connections on the side of the alt go like this( | | ) on externally regulated alts, and like this ( __ __ ) on internally regulated ones.
19GMC63 is offline   Reply With Quote
Old 08-24-2007, 07:35 PM   #6
Chevy Fleetside
Chevy Fleetside's Avatar
That is an internal regulator alternator and that is why you have all of the extra wires. If it is charging don't attach any more wires to it. The 3 holes next to the master cylnder are not needed. The last picture looks like the horn wires. Do you have a horn in the truck?
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 08-24-2007, 08:03 PM   #7
David Flores
David Flores's Avatar
Here are some wiring diagrams on my photobucket.
http://s191.photobucket.com/albums/z...nd%20diagrams/
66 c10 swbfs
My Build.
David Flores is offline   Reply With Quote
Old 08-25-2007, 11:50 AM   #8
satin64
satin64's Avatar
there is no horn.and the alternator isnt hooked up to anything,but i fiqured the wire should run to the battery positive side????i'll check the plug to make sure it runs --.thanks for the help and wiring diagram
Old 08-25-2007, 12:08 PM   #9
3speed 6cyl
3speed 6cyl's Avatar
those wires look like my front light link on my set. I'll post pics of my total rewire when I make progress
3speed 6cyl is offline   Reply With Quote
Old 08-25-2007, 12:52 PM   #10
satin64
satin64's Avatar
seems like allot of rewiring going on
Old 08-26-2007, 01:28 PM   #11
satin64
satin64's Avatar
i just scored a 64 GMC hood for a $100.and its about as cherry as you can get.i'll post some pics later.
Old 08-26-2007, 01:56 PM   #12
19GMC63
19GMC63's Avatar
nice! Sounds like a good deal. I've been looking for one too, the chevy hood is nice, but I love that GMC hood.
Old 08-26-2007, 08:25 PM   #13
satin64
satin64's Avatar
not much to see but its solid no holes or major dents.a few spots of surface rust.should clean up nicely,
Old 08-26-2007, 10:00 PM   #14
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
SO what is the difference between the 64 Chev and GMC hoods anyway ?
John
What the Heck is that ??
CURRENT BUILDS:
62 BurbMaster
Other Builds:
My '63 C-10,LWB,CC,BBW
'06 HD StrAight Axle Swap
Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build
AMERICAN CUSTOMS & CLASSICS (831) 630-1965
www.ACCHOLLISTER.com
ACC on FACEBOOK
"Rest in Peace, Mom & Dad ... I will see you again someday!"
ChiefRocka is offline   Reply With Quote
Old 08-26-2007, 10:20 PM   #15
Jonboy
Slots go on anything!
The peaks come around the front, and the turn signal lamps are shaped differently. Maybe someone can post a pic. One will bolt in place of the other.
Old 08-26-2007, 11:38 PM   #16
sanford66
sanford66's Avatar
GMC hood top, Chevy hood bottom. Joe
sanford66 is offline   Reply With Quote
Old 08-27-2007, 01:07 AM   #17
satin64
satin64's Avatar
are both of those yours?they look like good candidates to save.
Old 08-27-2007, 03:54 AM   #18
Stepside65
Still Truckless!
Stepside65's Avatar
I still want that grille Joe.
~James
Truckless
Tutor Et Ultor
Old 08-28-2007, 06:15 PM   #19
sanford66
sanford66's Avatar
They're mine. Stepside-the grill is still there. Joe
