08-24-2007, 08:54 PM | #1 |
Roof: Bad. Sky: Good.
Lowering K5 4WD front leaf springs
After swapping out the 33/12.5 BF Goodrich ATs for 275/60 street radials, the mechanic and I are getting ready to lower the '72 K5 4WD down to roughly stock level (maybe an inch or two lower). Assuming novices at work, we can use some help.
Here's a look at the undercarriage before the tire swap I checked the FAQ index and there is plenty of advice about dealing with rear leaf springs and front coils. What about the front leaf springs? Do you toss 'em and fabricate a coil setup? Or is there a simpler way of going about this? Thanks in advance for your help.
OleSenna |
08-24-2007, 09:14 PM | #2 |
Re: Lowering K5 4WD front leaf springs
You could simply remove some leafs from the pack... Or have yours flattened out more since only having one leaf might be fragile....
Not mush of a way to go lower than stock unless you want to move the axle over the springs... then you might open up a whole new can of worms...
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
08-24-2007, 10:13 PM | #3 |
is that the spring perches right under the springs? or is it a small lift block.
if perches i would buy a set of stock springs,you really need to swap out or at least cut off the excess threds on the ubolts,give you better under axle clearance. good luck..
jamie72 72 BB cheyenne -- Restoration getting started.. member #807 http://www.myspace.com/whitetailobsession www.antlertalk.com |
08-25-2007, 12:12 AM | #4 |
SKINNY TIRES RULE!
Most vendors carry or can order some stock leaf springs and u-bolts. I'm sure you can find someone to buy the current lift. You may even see if a local 4wd shop will make you a trade or give you a discount on some stock leafs.
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
08-25-2007, 07:24 AM | #5 |
Sounds like if you were running 33's, you had a 4" lift.
If so, Simply replace the lift spring's and any lift blocks with a set of stock spring packs and your done. Change the shocks out as well. Drive lines woudn't have been lengthened with only a 4" lift, you should be good to go there. |
08-25-2007, 10:31 PM | #6 |
Well if you had a 2 - 4" lift and are removing it, I might be interested in helping you "discard" the lift parts...
-Chris Building a stripper, one part at a time: 1969 K5, 307, 3spd, 3 seats, hard top. Added Pwr Discs, Pwr Steering, Aux Battery, T-case Skid, Lighted Sidemarkers, HEI, Lock-Right Diff, ECE Class IV Hitch, 32" MT/Rs. Parts to Install: Hand Throttle, Console, Tow Hooks, Dual Horns, AM-FM, Dealer Swing-Away Tire Carrier, Gas Tank Skid. Also building a 1950 Willys CJ-3A and off-roading a 2001 Nissan Frontier on 1-Ton Portals... |
