Old 08-24-2007, 09:37 PM   #1
Ricks1971
Ricks1971's Avatar
Cool tilt identification?
Hey guys got this tilt and not sure if its out of a 71 truck?
Ricks1971 is offline   Reply With Quote
Old 08-24-2007, 09:39 PM   #2
1969k10stepside
Re: tilt identification?
That's a van tilt.It will work in the trucks with some modifications though.
1969k10stepside is offline   Reply With Quote
Old 08-24-2007, 09:44 PM   #3
Ricks1971
Ricks1971's Avatar
is there a tread on how to modify it to work in a 72 chevy pickup?
Old 08-24-2007, 09:47 PM   #4
msgross
msgross's Avatar
like?
I agree that it looks like the van tilts that I have found... I would like to know all the modifications that it needs....
Obviously the rag joint coupler on the end needs removed from yours, then you need a steering shaft to connect to your current rag joint on your steering box. That short shift lever is pretty popular since a lot of guys put smaller steering wheels on than stock. The longer shifters look funny then...
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 08-24-2007, 09:51 PM   #5
1969k10stepside
The van tilts need the neutral saftey switch moved is one thing.On the end of the column where that piece bolts to the steering box on the vans..one bolt holds that one.Remove the bolt and that piece will come off.Then it will just have splines like a regular truck column.Then you just have to collapse the shaft in that goes between the column and steering box in the truck since the van column is longer than a regular truck column..then just slide the column in.You also have to swap out the grommet for the firewall to one from a truck.Some have the right wiring adapter,most of the newer ones dont and you need a $12 adapter.There is a FAQ thread on the conversion,check it out,it will answer your questions..
Old 08-24-2007, 09:55 PM   #6
jamie72
jamie72's Avatar
also need the wire harness adapter...unless you go cheap and cut-slice the wiring...don`t recommend.
jamie72
72 BB cheyenne -- Restoration getting started..
member #807
http://www.myspace.com/whitetailobsession
www.antlertalk.com
jamie72 is offline   Reply With Quote
Old 08-24-2007, 09:57 PM   #7
1969k10stepside
Some of the older van columns have the right plug but the newer ones need the adapter.It's only a $11 +/- item
Old 08-24-2007, 10:02 PM   #8
jamie72
jamie72's Avatar
thats not an older one...
jamie72
member #807
www.antlertalk.com
Old 08-24-2007, 10:39 PM   #9
72armyswbtruck
72armyswbtruck's Avatar
If you search FAQ's there is a build on this with pics. I will try and find the link, unleess someone else knows where it is.
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!"
72armyswbtruck is offline   Reply With Quote
Old 08-25-2007, 12:15 AM   #10
Ricks1971
Ricks1971's Avatar
Thanks for the info guys
Old 08-25-2007, 12:31 AM   #11
neonlarry
neonlarry's Avatar
Here it is:
http://67-72chevytrucks.com/vboard/s...threadid=63328
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 08-25-2007, 05:56 AM   #12
msgross
msgross's Avatar
...Then you just have to collapse the shaft in that goes between the column and steering box in the truck since the van column is longer than a regular truck column...
my van column was the same length as my nontilt truck column except that the steering shaft doesn't come off my non tilt, it's all one piece until you reach the shear pin....
The Garage:
Old 08-25-2007, 11:11 AM   #13
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
early 68's didn't have the colapsable intermidiate shaft.
