Old 08-25-2007, 01:10 PM   #1
69snb396
Daytime running lights
I just traded for an '01 Siverado and the daytime running lights won't work. I replaced both bulbs and the relay in the under-hood panel. I checked the 10 amp fuse adjacent to the relay and it's good. With the truck running in drive there is no voltage to the bulb socket. Any help appreciated. Thanks.
69snb396 is offline   Reply With Quote
Old 08-26-2007, 09:00 AM   #2
Joe67
67 is sold
Re: Daytime running lights
Sounds like the previous owner may have been one of the people who disable them for some strange reason.
I assume this is the case every time you start the truck? There is a button along the headlamp button that disables them, but it resets each time you turn off the ignition
Joe - Formerly 67c10step
1967 Chevy Stepside - ECE 4/6, fuelcell, 5lug - SOLD
gr8lakes - My ebay auctions
Click here to order forum apparel :: Click here to become a subscribing member
Joe67 is offline   Reply With Quote
Old 08-29-2007, 09:46 PM   #3
87 STEPPER
STILL PLAYS WITH TRUX
87 STEPPER's Avatar
Arrow Re: Daytime running lights
Is the green DRL light illuminated on the insturment panel with the engine running?
You may want to look at the Emergency brake switch connector it may be disconnected or jumpered there cuz if you set the E-Brake with the Ing. in the on or run position it disarms the DRL's.
~~Bruce~~
MY 87 STEPPER
MY 99 2D/WD TAHOE
87 STEPPER is offline   Reply With Quote
Old 08-29-2007, 11:25 PM   #4
N2TRUX
Happy to be here
N2TRUX's Avatar
Check the E-brake and make sure it's not pushed down a click or two. If you pushed them down a couple of clicks it would kill the power to the DRL's and not engage the brakes.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 08-30-2007, 11:17 AM   #5
BACKYARD88
On the fast track to nowhere..
BACKYARD88's Avatar
If memory serves me right those also only come on when the truck is in drive. Put it in gear and see if they come on
-Mike Owen-
Norwood, Houston, Cecilia, Jackson, Monroe and counting
BACKYARD88 is offline   Reply With Quote
