Old 08-25-2007, 03:43 PM   #1
drummin89
drummin89's Avatar
modern conveniences
on my 48 3/4 5 window, im adding some modern conveniences like power window, power seats and either power door locks w/ keyless or go with smooth door and have door poppers.
just want to know whats involved with adding these modern conveniences. seats should be easy, but not sure about the power windows or door popper/keyless.
pics are worth a thousand words.
power window kit
http://www.a1electric.com/Merchant2/...ct_Code=Master
power door lock/keyless kit
http://www.a1electric.com/Merchant2/...ode=W01F-B6000
door popper kit
http://www.a1electric.com/Merchant2/...ct_Code=POP-A2
im really liking the door popper kit, i will most likely be doing that instead of the power door lock/keyless kit, one reason because for 30 more you get all the door popper stuff.
Chris
52 Chevy 3600 (3/4 ton) 5 window pickup
-54 235 Inline 6 w/ Fuel Injection Conversion
-Clifford 2/4bbl Aluminum Intake and Headers
-1/2 ton front axle swap w/ 5lug disc brake kit
-CPP Power Steering Kit
Various pictures of my 52 Chevy 3600
drummin89 is offline   Reply With Quote
Old 08-25-2007, 06:02 PM   #2
CAL 58 GMC
CAL 58 GMC's Avatar
Re: modern conveniences
Bothers has a kit that uses a factory style regulator. The kit is not cheap, but it's one of the best out that just bolts in. Here's the link. http://www.brotherstrucks.com/prodin...number=NPW0000
CAL 58 GMC is offline   Reply With Quote
