Between Trucks...
Working on getting specs together for a new motor. What's the highest compression ratio I can get away with, for low octane, cheapo gasoline? I'll be running a pretty tame cam, not much more than .450 lift...
Beat it to fit, Paint it to match... ![]() |
Re: Compression ratios for cheap gas...
about 9to1
Between Trucks...
Cool,that's what I thought. Do you think 9.5:1 would be pushing it?
20' Daredevil (Ret)
![]() Join Date: May 2003
^ Gotta agree with that. Of course modern engine control systems allow considerably higher ratios, but I would think 9:1 would be about right for our old engines.
Ack, you beat me with your post! Mmmm 9.5:1 would probably still be OK, but that would be about the top. The worst that could happen is you might need mid-grade fuel...
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay Last edited by Stocker; 08-25-2007 at 04:14 PM. |
Aluminum heads will let you run higher compression on pump gas.You could go close to 10:1.I`m building a 327 with 76cc heads and flat tops.I`ll be at about 9.75:1 and I`m planning on running regular most of the time.If you run premium the mileage will improve enough with a light foot to pay you back about 1/2 the extra you spent on premium.(in any motor)
#6 | |
Do the Dew!
![]() BTW I run on midgrade pump gas which is 89 octane, 650 CFM Edelbrock, retarded the timing, and I am at about 5300 feet above sea level. ![]() |
Cam specs play a part in octane requirements with a given compression ratio. If you're stuck with 9.5:1 you can get a little leeway with cam selection. Some of the real tech guys can explain dynamic vs static compression better than I could. Call a cam company with what you need to do and they can help suggest the right cam specs.
![]() Join Date: Dec 2006
I always heard 8.7 for 87Octane and 9.5 for 92. My last engine was 9.0 and needed 89 octane or retard the timing or it would ping.
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, 2nd owner, Work-Truck supreme. Best $300 I ever spent. |
Sierra Grande Club
Altitude has a roll in compression ratios too. I’m in the 7000ft club. 10:1
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe. ![]() |
![]() Join Date: Mar 2006
Dang guys! first I want to know where to get CHEAP gas!!!!!!!!!!!!!!!!!!!!!!!!!!!!
LAIDOUT
Interesting, so less ambient pressure [altitude] means less cylinder filling, so less actual compression?
Sierra Grande Club
From what I hear, my 10:1 is = 9:1 at sea level. If I drive down in altitude I'll have to run premium.
s/t
#13 | |
Do the Dew!
I am not saying what you can or can't use gas wise, but at least keep in thought as to WHY that CHEAP GAS is so cheap. |
#14 | |
Between Trucks...
#15 |
We call it "spot gas".They just get it where it`s cheapest without any other consideration.
Hey Mtdewmaniac66,to answer your question..."Do you see a pocket protector and six pens? ![]()
#16 | |
Do the Dew!
![]() I had to laugh at that one, it reminded me of that commercial with the two lab techs driving identical cars but using different brands/types of fuels. I am sorry for the misconception though, I am use to seeing stuff that is crappy "cheap" while forgetting that "cheap" also meant "economically priced". While I would love to use the better priced fuel, I am using the midgrade fuel due to my engine requirements. |
#17 | |
blood type; Retumbo
CROWER HAS THEIR S!!T TOGETHER !! (grind # 00210) |
#18 |
Formerly yellow72custom
I have 9.7:1-ish in my truck, and it runs on 91 fine in the summer, and I can put 89 in it in the winter. I'm not exactly sure on the compression, but it has a 350 with stock-ish flat tops, with valve reliefs, stock Fel Pro head gasket, and 64cc double hump heads. The cam only has .440" lift.
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride. '70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck. '97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg |
