Old 08-25-2007, 11:17 PM   #1
kevinr1970
"K" case transmissions
This might be better in the Engine/Tranny forum but I'll start here.
I've heard of "K" case transmissions before but not sure what the differences are.
I was pulling the bad tranny (700r4) out of my '86 shortbed 4x4 today and noticed it has a "K" cast into the case near the front, on the driver side. It also has a tag that says "Remanufactured for GM".
I was going to have this one rebuilt eventually and put in my long bed. Just wondering if I lucked out and found something real nice.
It does need a rebuild though...
2009 Honda Fit CfC (bsf 44.9 mpg)
2000 Tahoe Limited
1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below
1991 GMC CrewCab Dually 4x4, just going to fix things up for now
1982/1989 K5/GMC Jimmy 2wd
1987 GMC 1/2 ton swb 2wd Crew (sold)
kevinr1970 is offline   Reply With Quote
Old 08-25-2007, 11:21 PM   #2
1969k10stepside
Re: "K" case transmissions
That's an easy question..."K" case means a 4wd..from the "K" series pickup,which is the 4wd line.Some have them,some I've seen dont.I've heard the torque convertor/flexplate cover is different on the "k" case trannys than the 2wd versions but I havent confirmed anything...Rare--no.
1969k10stepside is offline   Reply With Quote
Old 08-26-2007, 12:06 PM   #3
Pyrotechnic
Pyrotechnic's Avatar
I've heard that the K case is stronger. If the trans was being custom built, could a 2WD output and tail shaft be used to make a stronger transmission ? I've heard that the K case was stronger but it was not clear if it could be used for 2WD builds as well.
Pyrotechnic is offline   Reply With Quote
Old 08-26-2007, 01:57 PM   #4
kevinr1970
What I've heard is that the K cases are a stronger tranny and have heard of 2wd K case trannys too.
Locally a guy advertises rebuilt tranny's; not sure if he represents a shop or just does it as a side job. He advertises rebuilt 700r4's for $850 and had a 2wd K case for $1295. Can't find that add right now though.
2000 Tahoe Limited
