09-27-2002, 02:28 PM | #1 |
Steering wheel interchangeability...
I have caught some posts talking about the horn problems with Grant aftermarket wheels. I like the look/price of some of them, but I want my horn to work with the hub mounted button.
I also saw the recent post with the 71 chevelle wheel-- VERY NICE!, IMO... What steering wheels are a bolt on swap for my 72 (tilit wheel, column shift automatic, if that makes a difference) besides my original school bus wheel? Thanks!
Dutch 1972 Super Cheyenne K20 1976 MGB 1950 Harley FL 1997 Arctic Cat ZR580 "Maybe if I had a couple less hobbies, I'd have time to enjoy one!" |
09-27-2002, 03:41 PM | #2 |
ALL OF THE GENERAL MOTORS WHEELS HAVE THE SAME SIZE SPLINE (AT LEAST ALL THE AMERICAN MADE ONES) THIS INCLUDES PONTIAC,OLDS.GMC,CHEVYS, CADILACS ECT. ECT. YOU CAN PICK UP SOME REALLY NICE STEERING WHEELS CHEAP AT YOUR LOCAL BONE YARD.
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES// LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST |
09-27-2002, 03:50 PM | #3 |
Thanks, junkyardjohn...
...that's almost too easy! Is there a range of model years I need to stay within?
Thanks!
09-27-2002, 07:57 PM | #4 |
You can grab a early 70's to early 80's van column steering wheel and you might want to grab the shift lever also... the van ones are shorter and match better with the smaller steering wheel... and I'll take the original shifter lever off your your hands no problem...
Senior active founding member. 70 3/4 ton GMC Suburban 4x4 250/4 spd. 71 1/2 ton Suburban Chevy 4x4, 350/350 72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane 2005 FLSTSCI Harley Springer 85 FXSB Harley Lowrider 72 Triumph 650 Bonneville 5spd "Poor people don't have hobbies" Quote from wife. |
09-27-2002, 07:59 PM | #5 |
I'm probably going to pitch the van steering wheels in the garbage I have... they cost more than its worth to ship with a van tilt steering column if someone still wants them. Cheap.
09-27-2002, 10:40 PM | #6 |
DUTCH --- I'VE USED EM FROM THE EARLY 60s TO THE 90s & THEY ALL SEEM TO FIT. I'VE GOT A WHEEL OFF A MID EIGHTIES PONTIAC GRAND AM ON MY 71 BLAZER. IT SAYS POTIAC ON IT, BUT I'M NOT A PERFECTIONIST & IT SURE IS COMFY.
09-27-2002, 11:04 PM | #7 |
its all about the +6 inches
Early 90's S-10/C/K1500 truck wheel. Not my truck, but I have done it n the past.
09-27-2002, 11:21 PM | #8 |
Thanks for the help, guys...
...I'll get to the junk yard directly!
09-28-2002, 07:45 AM | #9 |
Old member
Steering Wheels
Here is a picture of mine it's out of a 80's corvette, with tilt column. Leather wraped.
