Old 08-26-2007, 03:03 AM   #1
3speed 6cyl
3speed 6cyl's Avatar
Help on bleeding new power brake system
I've bled brake lines w/ original reg. brake systems, but having problems bleeding power brake. Do I keep pressing my brakes and open and close valve at each wheel or use a jar w/ brake fluid at each wheel brake line end( one at a time). Is there something different about bleeding power brakes
3speed 6cyl is offline   Reply With Quote
Old 08-26-2007, 03:17 AM   #2
poorboy
poorboy's Avatar
Re: Help on bleeding new power brake system
Bleeding the power brakes is the same as manual.
63 short fleet Patina build
http://67-72chevytrucks.com/vboard/s...d.php?t=287751 Man I want another one.
poorboy is offline   Reply With Quote
Old 08-27-2007, 01:12 AM   #3
Brad54
Brad54's Avatar
Make sure you bench bleed the master cylinder first. You'll never get the spongy feeling out of the brakes if you don't.
-Brad
'61 Suburban daily driver: off the road due to 180-pound 8-pt buck!
'62 K-10 long-step project
'61 C30 Camper, aka "Valdez"
There's no cool like Old School
Brad54 is offline   Reply With Quote
Old 08-27-2007, 01:33 AM   #4
3speed 6cyl
Thanks good buddy, I successfully bled my new power disc brake system. Master cylinder U turn bleed first then bled the rest of the system like an ol' school manual brake system. 100-200 total pumps for a new empty system though. took a while before I felt good pressure in the pedal THANKS
