Old 08-26-2007, 08:31 PM   #1
satin64
satin64's Avatar
flip kit..hows it work?
i got these parts,i do have 2 of each plus shock mounts.i know i need a c notch too.but there is no instructions on how to flip the rearend on top of the springs.i got these from a friend who didnt use them off a 2000 silverado.i was hopeing they would work on my 64.since it to has leafs.any ideas,suggestions would be appreciated.
satin64 is offline   Reply With Quote
Old 08-26-2007, 08:45 PM   #2
pcmcobra
pcmcobra's Avatar
Re: flip kit..hows it work?
not sure on the 64.
Here's a link to djm install instructions, It's pretty easy, at least on my 86 it was.
http://www.djmsuspension.com/Instruc...p/FK1024-5.pdf
1986 C10 SWB 6.0/6l90e
Miami...Flee it like a native
pcmcobra is offline   Reply With Quote
Old 08-26-2007, 08:54 PM   #3
satin64
satin64's Avatar
thanks, now for some reading....
if i got longer u bolts,would it be safe to add a 1 or 2 inch block?
Old 08-26-2007, 09:03 PM   #4
action
Active Member
action's Avatar
if i got longer u bolts,would it be safe to add a 1 or 2 inch block?[/QUOTE]
It has been done many times before so I think you will be good.
Jack
68 Chevy Long utility bed.
Now swb/Bagged
Soon to be 468 (Maybe 496) BB/Turbo 400
action is offline   Reply With Quote
Old 08-27-2007, 12:54 AM   #5
satin64
satin64's Avatar
what about the spring perches???do i cut them off?or???
Old 08-27-2007, 11:59 AM   #6
action
Active Member
action's Avatar
Some flip kits use them to set pinion angle with the new parts. If your kit doesn't you can leave them or cut them off.
Jack
Now swb/Bagged
Old 08-27-2007, 03:04 PM   #7
satin64
satin64's Avatar
i dont think this kit does use them.kit is a lose term since it came off a truck that was switching to bags.guess i'll have to just do it and see what happens.
