08-27-2007, 10:22 AM | #1 |
Emptying gas tank question
I pulled the gas tank from my truck to clean it out in preparation for a new engine. The tank is clean with no rust but does have a tiny amount of junk in the bottom. I have tried draining the remaining gas from all three openings(see picture) but cannot get the final quart, or so, out. This concerns me because I would like to wash out the inside. I was planning to wash it out with hot water and then alcohol or lacquer thinner. However, if I cannot get all of the gas out, I will not be able to get the water/alcohol/thinner out. So...what am I doing wrong when trying to get the gas out of the tank????
08-27-2007, 11:01 AM | #2 |
Re: Emptying gas tank question
Let it sit outside for a day in the sun and let it evaporate out. You could also blow some air into the tank-----if you have a compressor
08-27-2007, 11:12 AM | #3 |
you cant get it out from the fill tube because it doesnt mount flush to the inside of the tank/ the best sloppy way is thru the sender hole// i use apressure washer to dislodge the crap inside then get all you can out byshakin it out thru the sender hole and using a wetdry vaccume with reducers and extensions to finish it off
08-27-2007, 11:29 AM | #4 |
Is there a explosion risk with using a vacuum even after blasting the tank with a high pressure sprayer?
08-27-2007, 12:15 PM | #5 |
there should not be any fumes after a good long powerwash cycle
08-27-2007, 12:28 PM | #6 |
Spanked once
Yes, The only way you could get me to use a vacuum cleaner would be explosion proof . Hot soapy water a few times and maybe power wash and use some of that N.C. sun to bake it dry.
08-27-2007, 12:38 PM | #7 |
upgrading to an older model
wrap a rag around a stick (make sure you can hold onto the corner of the rag) and sop up the liquid...then let it air dry for a day or so and all should be good. My Dad got some lawn mower gas from a guy that passed away and had an in-ground tank...obviuosly it leaked because I have gotten watered down gas 2-3 times and this method has worked for me.
68 stepside, short-box, multi-colored (for now) |
