08-27-2007, 11:10 AM | #1 |
bed wood
Bed wood will be here wed. It will come sanded I have to finish it, is it best to brush on or can you use a sprayer to put varinish on. Just need some help with what others have done. Thanks for any help.
08-27-2007, 11:46 AM | #2 |
Re: bed wood
Couple weeks ago on Gearz, Stacey used a HVLP paint gun to do a set and even used an automotive clear coat. Looked great. He said you could then buff it just like your auto finish.
Wouldn't recommend it if you really wanted to use the bed...but damn it was pretty sweet..
'67 C10 SWB Frame off (and smiling) |
08-27-2007, 12:13 PM | #3 |
Re: bed wood
to get an optimum finish you'd need to finish sand it before starting applying anything// brush or spray you can get an excellent finish either way// if you do use a brush the quality of the brush has alot to do with finished looks a $25 brush gets a better finish than a $3 homedepot allpurpose one// ive seen a lot of dropdead woodwork on multimillion dollar yachts done with a brush
08-30-2007, 02:33 AM | #4 |
Re: bed wood
Bed Time Story is a post that I just finished. It is a very complete post from start to finish. We used a sponge applicator, no chance of getting brush hairs in your work or air bubbles that can result with a brush.
esll.
Tomorrow is for doing today's stuff. ************************************* This truck has just the right amount of energy for me! Author: Warren Lake .... (member) |
08-30-2007, 07:32 AM | #5 |
its all about the +6 inches
Re: bed wood
If the truck will spend much time outside, then you need to make sure the varnish is UV safe.
I've never made it to this point on any truck of mine, but I've read on here that you'd be best off with a marine grade of finish, or you can stain it and then use an automotive clear coat. |
08-30-2007, 07:55 AM | #6 |
KEEP ON TRUCKIN'
Re: bed wood
The marine varnish is best to use if exposed to the elements. Like they said above, use a good brush and sand between coats. After you have all the coats you want on the wood, sand the boards with a sanding block starting with 1000, 1500, then finish with 2000. When you are done sanding you can start buffing. Use a good quality compound and work up to the mirror finish that you are looking for.
JIM '97 GMC Sierra K1500 '95 Chevy Silverado C1500 '71 Cheyenne Z71 / LT1 & 4-Speed SWB K/10 Father/Son Project http://www.youtube.com/watch?v=4l689JKXPnA http://67-72chevytrucks.com/vboard/payments.php "LIVIN' FREE FOREVER" |
08-30-2007, 10:53 AM | #7 |
Re: bed wood
I cannot drive in the winter time, hell for that matter night time. But I didn't want to baby this truck so I did the stain and the tinted clear in Sikens. Sikens offers UV protection in their products. This is a Swedish company and the word Sikens means "FOREVER." It comes in satin or gloss. I choosed satin. I used this on my house outside as well as inside. This is made for the elements and you have a huge choice of colors to choose from.
Good luck with your project, esll.
08-30-2007, 10:59 AM | #8 |
Re: bed wood
Here are some pictures of my bed finished in Sikens.
08-30-2007, 11:56 AM | #9 |
Re: bed wood
Outstanding info, thanks
And the bed floor looks kick ass too |
08-30-2007, 12:24 PM | #10 |
Re: bed wood
east side, how many coats did you use and did you sand in between coats. Was your wood pre sanded. Thanks for the sikkens info. I have plans to do my bed friday and saturday, your bed looks great i only hope mine will turn out like that. thanks again for your help.
08-30-2007, 01:48 PM | #11 |
Old Duffer
Re: bed wood
A marine varnish, and some throw-away wood handled foam brushes. Cut the varnish about 30% with turpentine for the first coat to seal the grain. Cut the second coat 10%. Then apply 3 or four more coats full strength, sanding lightly with 220 grit paper in between. The varnish is mechanically bonded so the sanding scuffs the surface for bonding as well as smooths out the previous coats.
You can build up to 6 or 7 coats which makes a touch up easier. My thought is, if it works on boats in a severe invironment, it oughta work on a truck bed. My favorite is Interlux Schooner #96.
'68 Short C20 Flatbed Dually w/ 292 4bbl, Langdon cast headers, and WC T5 trans. '81 G10 Shorty Van "Good judgement comes from experience, and a lot of that comes from bad judgement." Will Rogers "Under promise, then over achieve." |
08-30-2007, 02:12 PM | #12 |
Re: bed wood
good god that is beautiful!
08-30-2007, 03:11 PM | #13 |
Re: bed wood
I don't think too many people are using their nice wood beds anymore as haulers. I have gone to using automotive clear cloat as a wood finish several years back on the vintage wood propellers we manufacture. It does not yellow with age, UV proof, and durable. Problem with sanding andthing finer that 150 will clog the pores of the grain. Once you are done sanding, wipe the boards down with a wet rag, not wringing wet with water dripping in the floor. It will open the pores and stand the grain up. It will feel rough again but will allow the finish to penetrate deeper into the wood. Apply 1-2 good coats, let it cure. Finish sand with 320/400 and apply 2 more coats and the wood will be as smooth as a baby's a$$.
Mike Redpath |
08-30-2007, 03:34 PM | #14 |
Old Duffer
Re: bed wood
Thank You, Longhorn. Here's a couple shots of the other end. BTW, I do use this to haul. I have two pieces of plywood with carpet on the bottom that matches the skid strips. When I'm going to use it I just strap down the ply's and go.
Sorry, don't mean to hijack the thread!
08-30-2007, 03:58 PM | #15 |
Re: bed wood
what are those 2 studs on the bottom side of the hood, by the six appeal sticker?
08-30-2007, 04:19 PM | #16 |
EZEKIEL 25:17
Re: bed wood
Andy look closer they are magnet hooks holding the six appeal plaque.
68 CHEVELLE(HORSESHOE) 69 LONGHORN 396 70 NOVA 454(FOR SALE) 71 SWB 307 71 EL CAMINO 383 72 GMC JIMMY 350 87 BLAZER 350 WIW? http://blog.360.yahoo.com/blog-r5CJt...9_6Orzim4L5uWM Gun control, the theory that 110lb. women have the "right" to fistfight with 210lb. rapists. The reason animal rights activists are more passionate about fur than leather is because it's safer to harrass rich women than bikers... |
08-30-2007, 04:38 PM | #17 |
Re: bed wood
ahhhh, I see.
08-30-2007, 05:12 PM | #18 | |
Re: bed wood
I used two coats of Sikens dark oak stain and two coats of their clear tinted UV protectant clear coat. Every coat stain or clear is sanded in between. All the boards FOR "THEIR FIRST SANDING ONLY" were sanded with the grain with an electric sander with 150 grit. Air blow sanding residue off and stain. For every other coat we scuffed the boards with 4 zero Bull Wool. esll.
08-30-2007, 05:17 PM | #19 | |
Re: bed wood
Sweet truck!! Nicest flat deck that I've seen and I like the six banger they were good engines. esll.
08-30-2007, 11:05 PM | #20 |
TOTY 2006
Re: bed wood
slomotion!! What an awsome flatbed!!!!! I always liked those styles of flatbed, and I do believe that in a few years I will build one!!!
08-31-2007, 11:53 AM | #21 |
Old Duffer
Re: bed wood
Thank You, it's a lot of fun to run around in.
08-31-2007, 11:57 AM | #22 | |
Re: bed wood
Scott 66 chevy short step 327 4speed 67 chevy Short Fleet tpi 350 700r4 72 chevy K10 swb 01 GMC Sierra 01 Pontiac Bonneville |
08-31-2007, 12:17 PM | #23 |
Re: bed wood
I used Duron marine spar varnish. Appled about 5 coats sanding in between with 240 grit sandpaper. I used a good China bristle brush, the varnish is self leveling while drying so it don't leave streaks. I had to find a real dust free area to use for applying the paint because it attracts dust and anything else in the area.
Richard Dobson |
08-31-2007, 02:00 PM | #24 |
Re: bed wood
Mike Redpath |
08-31-2007, 02:51 PM | #25 |
Re: bed wood
Those wood bed floors are nicer than the wood floors in my house!
Dano
'69 Fleet It ain't yours, if you didn't build it! |
