08-27-2007, 12:47 PM | #1 |
Active Member
Correct me if I'm wrong re: differential ID...
I was looking at my 69 Chevy yesterday and decided to check the rear end ID numbers just for the heck of it.
I swapped it many years ago and it I think it came off a 1970 truck. It's a 12 bolt differential with these numbers:TDE 12 22 W2 TDE--3.07 12----month of Dec. 22----Day of the month W----Warner, Michigan 2-----this I'm not sure of. One site I found said it was the 2nd work shift?? Last edited by 68gmsee; 08-27-2007 at 12:51 PM. Reason: Typo should be TDE |
08-27-2007, 03:38 PM | #2 |
Re: Correct me if I'm wrong re: differential ID...
It's a 307 unless someone changed the carrier and gear during a 37 year span. It's also at least a 70,because it has a 3 letter code. Housing should measure 57" from backing plate to backing plate.
08-27-2007, 05:07 PM | #3 |
Active Member
Thnx, Uncle. I figured the data was correct but some sites differ in the information you get so I wasn't sure. I am fairly certain the gears have never been changed out.
I guess I'm satisfied with that ratio. It's got a worn down 350 with a 350 turbo hydramatic that I took off a 77 Impala and I want to put a crate engine in it. I intend to use it as a daily work truck for lite hauling when I put it back together. |
