Old 08-27-2007, 02:40 PM   #1
ChaseDale3and8
ChaseDale3and8's Avatar
Dash
I was out at this years swap meet and I saw a shortbed 4x4 truck like mine that had the dash removed and had a custom set of gages put in. This truck was built for off road racing, and had a lot of custom work including a full rollcage.
Anyway, I started thinking about the dash being taken out of this truck and how did they do it. Does the dash simply bolt in on the sides and to a brace or two in the center, or is it bolted in and spot welded as well?
The reason that I'm asking is that my dash has been cut out for a CD player and I would someday like to restore it back to stock. I can pick up a dash for my truck at the salvage yard dirt cheap I'm sure but I need to know if it's going to be spot welded somewhere or if it's just bolted in. Thanks for any replies. ...Joe
I'm not speedin'! I'm qualifyin'!
ChaseDale3and8 is offline   Reply With Quote
Old 08-27-2007, 03:28 PM   #2
dooce
Re: Dash
I had the same problem. I had a parts truck laying around about a year ago and figured the dash just bolted into place. I took everything apart to find out that the dash is pinched and spot welded right below the bottom of the windshield and I think a bolt on either end. I ended up not messing with it and made a patch panel (I guess is what you'd call it) to weld in place of the cut up hole. It worked really nice, and I still have one laying around somewhere. I made mine to work for an aftermarket stereo, the owner before me cut mine WAY too big. If you would like, I can send you a blueprint with dimensions, but the sutout would have to be changed to a factory stereo if that is what you'd like. let me know.
1976 Chevy 1/2T 2wd SWB
327/Saginaw 4spd 3.73:1
LQ4 6.0/T56 Build thread http://67-72chevytrucks.com/vboard/s...d.php?t=772071
LFSalleeII@gmail.com
dooce is offline   Reply With Quote
Old 08-27-2007, 03:44 PM   #3
ChaseDale3and8
Re: Dash
Thanks! If you have the dimensions just PM them to me. I thought about just having the salvage yard just cut the whole section out that I would need and then I could trim it down to what I need if nothing else. Thanks for responding. ...Joe
Old 08-27-2007, 04:59 PM   #4
dooce
Re: Dash
here is the drawing I said I would get for you. Like I said in the pm, it is very rough and may need some tweeking to the dimensions, but this will get you close enough.
edit: it wont let me add an attachment right now. Im not sure why, but I will try again later.
Old 08-27-2007, 05:05 PM   #5
dooce
Re: Dash
I think I got it.
Old 08-27-2007, 05:08 PM   #6
ChaseDale3and8
Re: Dash
Thanks! ...Joe
Old 08-27-2007, 05:11 PM   #7
dooce
Re: Dash
I edited the pic, one of the dimensions was off. It looks good now.
Old 08-27-2007, 07:23 PM   #8
Grande Rojo
paper or plastic?
Grande Rojo's Avatar
Re: Dash
I spent most of the day out there at the Auto swapmeet. I guess I missed that truck. The worst part of the day was I did not buy anything!!
Grande Rojo is offline   Reply With Quote
Old 08-27-2007, 09:02 PM   #9
ChaseDale3and8
Re: Dash
You should've met up with me. I could have helped you spend money! Oh yeah,that truck was the white one in the car corral. It had the flared out fiberglass front fenders and hood on it, 6 inch lift, 35s and a 454 under the hood. ...Joe
