08-27-2007, 03:40 PM | #1 |
Junior Member
What caused this?
Melted my negative battery cable.
71 Suburban 350/700R4 Project Trixie 72 CHEVY,Highlander,SWB,396,T400 Last edited by BB72CHEVKT; 09-03-2009 at 03:42 PM. |
08-27-2007, 03:45 PM | #2 |
Re: What caused this?
loose connection causes them to heat up. The other cable you have there should be replaced also. The end you have on it is supposed to be a temporary/emergency repair.
08-27-2007, 03:51 PM | #3 |
It looks like that end was soldered to the next section - what ever caused the overheating melted the solder - that doesn't look like a "splat" of copper there, just solder....
"A cat will almost always blink when hit between the eyes with a ball peen hammer" (you don't always have to state the obvious) Wear your PPE! You can eat with false teeth but you can't see with a false eye. 1959 Studebaker Silverhawk 350/400 1972 C10 L6 3OTT 2005 F350 - Built - whew! |
08-27-2007, 03:58 PM | #4 |
Yep, I agree, someone did a bandaid fix instead of replacing the cables. Replace both cables with new ones and make sure that they are routed so that they don't come in contact with the hedders or other problem areas that may cause them to rub.
