Old 08-27-2007, 09:50 PM   #1
f.monroe
f.monroe's Avatar
Bought a Suburban
I asked a question about converting to TBI on my old 77 . I picked the suburban up today since it rained and there wasnt anything else to do . It turns out it is a 1989 Sub. and there are plenty of good parts . I wish it wasnt a 10 bolt 6 lug rear since it appears to have 3.73's . I would have liked to use the rear in my truck . I have a couple questions about the thing .
1- Are suburban rear leaf springs the same as truck springs?
2-When I pull the computer and injection out , should I take the entire under dash wiring or should I buy an aftermarket wiring harness like Painless Wiring .
3- are there any significant differences on the under dash A/C components?
4- If so would it be worth swapping the A/C controls and main box into the old truck . The newer controls seem to move easier and I assume are more electric than cable operated .
5- Are there performance camshafts and chips still readily available for TBI motors ?What experiences have you had with them?
I intend to have the truck painted and wonder if it would be worth gutting the cab and installing these things after it is painted .
I am thinking about pulling the engine from the suburban and rebuilding . That way I will have a new engine if I get the fuel injection transferred over . I am going to have a parts listing maybe this weekend on the parts I dont intend to use . I will get pics and post it on the parts board . Sorry about the long post . If you can answer any of the questions , please do . Frank
Born and proudly residing in a Red State !
f.monroe is offline   Reply With Quote
Old 08-28-2007, 12:13 PM   #2
beaterC10
Re: Bought a Suburban
You can use the 6 lug rearend by swapping in a set of 5 lug axles.
beaterC10 is offline   Reply With Quote
Old 08-28-2007, 12:48 PM   #3
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
1- Suburban (if it has 6 lug means it is a 4x4) I believe they used the 56" (HD springs) They are the same, but might not be the same as what you have.
2- I would get everything from the ECM plugs to the motor and mark those that are tied in. It only takes like 4 wires to make it work. If it ends up being to much to worry about, then go the easy route.
3- same, you can swap the units out if you like, but they were still vacuum.
4- only if you wanted to add some work to your project with no gains (except maybe better seals...
5- yes they are still availible, I don't have personal experience with them though. thirdgen.org has alot of guys messing with them though.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 08-28-2007, 02:40 PM   #4
MylilBowTie
Right turn Clyde
MylilBowTie's Avatar
So are the spring perches the same width apart as the trucks?
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73
1992 Camaro RS 305 TBI
MylilBowTie is offline   Reply With Quote
Old 08-28-2007, 03:41 PM   #5
Captkaos
Captkaos's Avatar
Spring perches as in where the springs mount on the axle?
Chris Lucas
1973 Chevy C-10
Captkaos Customs
Old 08-28-2007, 03:45 PM   #6
MylilBowTie
Right turn Clyde
Yes. I was wondering if the suburban rear would swap with the truck rear? But wasn't sure if the spring perch's would need cut off. Then welded back up in the correct spot.
Old 08-28-2007, 05:15 PM   #7
Captkaos
Captkaos's Avatar
they are the same width.
Chris Lucas
1973 Chevy C-10
Captkaos Customs
