Please help Will it work or will there be problems ?
will a complete break system from a
3/4 ton with drum brakes work on a 1/2 ton 4x4 with disk? I want to use just about everything from the 3/4 ton 2wd....power breaks.. booster,master cylinder,proportioning valve. everything except for some new brake lines, and put it on the 1/2 ton 4x4 with disk break truck. Last edited by xshadow; 08-28-2007 at 12:03 AM. |
Re: Please help Will it work or will there be problems ?
the booster will work but i would not count on anything else
common sense isn't so common anymore |
Master cylinder might work but not the Prop valve.
Mario and Mandy Hughesville, MD 20637 69 C10 305/350 71 K5 Basket case 75 K10 Rescue **Parting out** 77 MG Midget **Parting out** 15 6.7L Cummins |
has anyone done this?
