Jumped Timing..???
![]() I was looking to rebuilding the 455 buick in my 70 C10 this winter. It leaks in a couple spots, I dont know the age or miles, and I just figured I'd finally rebuild one for the first time. I was planning for these in the Dec/Jan timeframe. However....... Today, I was getting a little ![]() After the insurance towed it home (thank goodness I added that extra 2.00 a month on the policy), I determine that fuel is getting to the carb (has electic fuel pump and I can see it) and I pulled the number 1 spark plug and I am getting spark (has HEI distributor). When I try to start it sounds like it wants to start, spits and sputters but cannot get itself running. It might limp along for a couple seconds and die again. Giving it gas tries to make it better but it cant hang in there. There are no major bangs, knocks, or crashes... Is it possible I jumped the timing chain?? Whats the best next step? I am tinkering with determining the compression stroke and finding TDC for #1 cylinder, then lifting the cap to see where the rotor sits but I dont have all the tools or prior experience...just operating on my own analysis... Any tips or secrets of the trade?? Oh yeah, I just bought the truck 4 months ago..... ![]() Thanks for any advice....Tank |
Re: Jumped Timing..???
I'd say it either jumped time or the distributor worked loose and moved.
Oh yeah, I looked at distributor hold down and it looks to be in the same spot. You can see the groove and marks from where it sits. Tank
#4 | |
The LuvShack Garage
I'm no expert, but there are plenty on here, someone will help you out w/ this ![]()
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Tow Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
![]() Join Date: Jul 2006
Where is your timing currently?
Does it drag at all when you try to start it? Jumping a tooth is rare but possible. |
I've had one jump time and while trying to adjust the dizzy to get it drivable, it jumped again as soon as it got enough combustion on the power stroke. I had to get a new timing set. If you can get it running better by guestimating with the dizzy (the balancer mark won't be close), it won't be long before it jumps again.
