![]() Join Date: Oct 2005
Late model chevy bench...will it work?
This is the rear seat out of a 96-06 extended cab.
Has anyone tried this?....could you modify regular brackets to fit?....is it too wide or short? Looks like it may be a bit skimpy on padding......don't know. Does anyone else?
72 Cheyenne SWB Fleet Nut & bolt frame off in progress...99.9999% - supercharged 383 - 4 wheel discs - relocated fuel tank - ![]() My Build Thread Last edited by SactoJim; 10-04-2007 at 05:29 PM. |
Re: Late model chev bench...will it work?
You might be able to make it work, but I'd be leary of it. I have an `03 Sierra with the same kind of bench in the extended cab. I can tell you the bottom is shorter than a normal front bench and the back is more straight up and down to make it fit in an extended cab. Might be a bit awkward in actual usage.
Plus you'd definitely have to make new brackets for mounting. They are offset. Last edited by DoobieBrother; 08-28-2007 at 06:00 PM. |
![]() Join Date: Jul 2006
I've heard the rear seat from a tahoe bolts right in or close to it. I have a seat out of a '91 in my '68. Had to do a little drilling but it fits nice.
What year tahoe are we talking about. My current seat is lacking in comfort and looking for something to replace it with.
I have a late model front seat in mine,
1968 Short Fleet 350/700r4 http://67-72chevytrucks.com/vboard/s...d.php?t=249435 1997 Bagged XtdCab Vortec350/4L60e http://67-72chevytrucks.com/vboard/s...44#post2286144 1993 XtdCab Longbed 4x4 6.5Turbo/NV4500 "Daily Driver" 1985 Toyota XtdCab 4x4 22re/W-56/Dual T-cases, Doug Thorley Header, Homebrew front and rear spring packs, Tons of Mods to suspension and drivetrain, 35" boggers, coming soon ARB's and 5.29's, Possible 4.3/700r4 swap |
yes i have one in my truck the seat is a 1988
1967 chevy one ton wrecker truck |
Yes. Tahoe middle row would work much better than extended cab back seat. It has more bottom to it, a more reasonable back angle, and brackets that aren't offset.
Between Trucks...
Hey Alschevy, did that seat bolt right up, or did you have to drill any holes?
Beat it to fit, Paint it to match... ![]() Last edited by Sinister; 08-29-2007 at 07:40 PM. |
Old Skool Club
![]() Join Date: Jun 2001
I have a second seat from a '98 Tahoe, in tan leather. It isn't what I wanted, but it's what I have. PUTTER has one in his truck and had a nice thread on how to install it.
What I really want is a 40/20/40 seat like the one in my '96 Sierra regular cab. A 92-99 second-row seat from a Tahoe or Suburban has no fore/aft adjustments, so you'll have to fit it to your truck for your butt. The flop-forward bottom cushion gives some storage space that is easy to get to. I think two holes line up and you have to drill two more and add something to space the seat into the right angle for your liking.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
Re: Late model chevy bench...will it work?
My seat did bolt in. but i am still looking for a 1967 or 1968 bench seat thats
in good shape 1967 chevy one ton wrecker truck |
