Old 08-28-2007, 05:38 PM   #1
19GMC63
19GMC63's Avatar
e-brake ideas.
Even though my truck is 4 hours away, I'm still thinking of what needs done.
On my to-do list is an e-brake setup.
I have the actual handle, and the e-brake crossmember is there, but the setup isn't bolted/rivited on.
Can I install an aftermarket setup, from someone like lokar? Has anyone done this? I'm thinking of just converting to a pedal setup.
What are yall's suggestions?
thx
19GMC63 is offline   Reply With Quote
Old 08-29-2007, 07:35 AM   #2
psychorodder
psychorodder's Avatar
Re: e-brake ideas.
I bolted handle under column where it used to be, and bought lokar cables ,installed them made a bracket under the truck and they work great.
psychorodder is offline   Reply With Quote
Old 08-29-2007, 11:46 AM   #3
19GMC63
19GMC63's Avatar
Re: e-brake ideas.
any pics of that bracket?
Also, if you don't mind me askin, how much did you think you spent on this setup?
Old 08-29-2007, 09:43 PM   #4
psychorodder
Re: e-brake ideas.
I got cables on ebay bracket just a piece old steel plate I welded to frame and ran both cables, then to handle I spent about100 on all I put new cable from handle to welded bracket I will try and send picture. Just ran all cables then figured where bracket would work best. Dry fitted everything and welded in leave room so rod can be adjusted, really simple and cheap, work better than original.
Old 08-29-2007, 10:42 PM   #5
19GMC63
19GMC63's Avatar
Re: e-brake ideas.
so which handle did you use? The stock pull type or foot operated? New lokar handle or stock?
And pictures would be awesome.
thanks
Old 08-30-2007, 03:58 PM   #6
psychorodder
Re: e-brake ideas.
The stock handle, ran new cable to bracket where two cables from back meet. The lokar lines hane the small bracket to go from one line to the two lines to rear I will try and send some pics this weekend.
Old 09-02-2007, 10:14 PM   #7
19GMC63
19GMC63's Avatar
Re: e-brake ideas.
so do you think this would work?
http://store.summitracing.com/partde...80FU&N=700+115
Old 09-06-2007, 08:55 PM   #8
19GMC63
19GMC63's Avatar
Re: e-brake ideas.
bttt
Old 09-12-2007, 12:12 AM   #9
19GMC63
19GMC63's Avatar
Re: e-brake ideas.
ttt
Old 09-21-2007, 06:11 PM   #10
19GMC63
19GMC63's Avatar
Re: e-brake ideas.
bump
Old 09-26-2007, 01:11 AM   #11
19GMC63
19GMC63's Avatar
Re: e-brake ideas.
no one?
Old 09-26-2007, 01:26 PM   #12
is2blu
is2blu's Avatar
Re: e-brake ideas.
mine has an E brake from a late model I harvested from crusher truck, shortened cables and installed the lever from the donor. works cool and does away with big handle under column.
keep on truckin',
gaileen
is2blu is offline   Reply With Quote
Old 09-26-2007, 09:25 PM   #13
David Flores
David Flores's Avatar
Re: e-brake ideas.
Here is a board members ebrake. Not sure how it is set up though.
66 c10 swbfs
My Build.
David Flores is offline   Reply With Quote
Old 09-26-2007, 09:45 PM   #14
19GMC63
19GMC63's Avatar
Re: e-brake ideas.
whos truck is that? Thats one nice interior!
Old 09-27-2007, 12:07 AM   #15
SkylineNXS
SkylineNXS's Avatar
Re: e-brake ideas.
I agree, very nice. My trucks 3.5 hrs away, but i finally get to go up this weekend and get it ready and on the trailer to bring down to me....soo very very happy...
BRAD
2000 GMC Sierra EXT Cab Short 4x4, finally mine...
1966 C10 SWB Fleet, 250 I6, three on the tree....
Previously Owned....
1987 Chevy R10 "Silverado" (at least the badges were) Short Step 350 700r4....
1972 Chevy LWB Fleet 350/350
EXTENDED CAB ALL THE WAY!
.._..~...-...._...____
.._..-...______|_|__\____
..-..~.|_(O)__|_|__|_(O)]
SkylineNXS is offline   Reply With Quote
Old 09-27-2007, 10:12 AM   #16
coolair
Re: e-brake ideas.
Hey! That's my truck! The parking brake lever is one I picked up @ a swap meet. I drilled a hole in the vertical part of rise or bump in the trans tunnel - attached an all-thread rod to the handle and made a pivot assembly under the cab - sorry no pictures. I'm not 100% happy with it yet, it will hold the truck on level ground (good enough to pass state inspection) but wouldn't trust it on an incline. Luckily not too many hills in SA,TX and with an auto trans, I never set the brake anyway. I do have a plan in mind and will rework it this winter (once I get my two post lift installed) and I hope for better operation.
Thanks,
Mark
coolair is offline   Reply With Quote
Old 09-27-2007, 03:11 PM   #17
19GMC63
19GMC63's Avatar
Re: e-brake ideas.
all this trouble I'm having with the e-brake is almost enough for me to do a TH350 swap.....
...nah.
Old 09-27-2007, 09:33 PM   #18
LIVE RUST
1966 Chevy/GMC Mongrel K10
LIVE RUST's Avatar
Re: e-brake ideas.
That avitar is unbelievable!
LIVE RUST is offline   Reply With Quote
Old 09-27-2007, 10:04 PM   #19
19GMC63
19GMC63's Avatar
Re: e-brake ideas.
in a good way?
Old 09-27-2007, 10:36 PM   #20
LIVE RUST
LIVE RUST's Avatar
Re: e-brake ideas.
Yeah! I think?
Old 09-28-2007, 04:03 AM   #21
63 & 64 Bowties
and a few others
Re: e-brake ideas.
how do you get "moving avatars?" is that a link to something or a mpeg, or what? I see some that are like photobucket type slide shows with a couple views of their trucks that change every second or so. how's that done, anyone know?
:tj:
Bill US Army Vet -193rd Infantry
BlueRidgeMuscleCars.com
“The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi
63 & 64 Bowties is offline   Reply With Quote
Old 09-28-2007, 12:08 PM   #22
19GMC63
19GMC63's Avatar
Re: e-brake ideas.
the only format that's animated is GIF (graphic interchange format). The only problems with gif's are file size, you can only bring it down to 4 or 5 frames or slides in order to be below the avatar limit (24.4kb)
I just took an existing one and shortened the number of frames and made it smaller overall using adobe imageready (comes with photoshop).
I can make you guys a slideshow one if you want me to. Just give me some pics. Or if theres one on the internet you find, I can try to make it legal avatar size.
