Old 08-28-2007, 06:23 PM   #1
68gmsee
Active Member
68gmsee's Avatar
What to do about bowed hood problem..
I've got a hood that I bought as a spare and noticed it has a slight bow in the center like the one on my 69 chevy. My 68 GMC doesn't have it.
I've also noticed the same on other trucks and have to assume that it's not uncommon. Seems to be a weak spot than could use some bracing. What, if anything are you all doing to fix? Or is it something we just live with.
68gmsee is offline   Reply With Quote
Old 08-28-2007, 07:08 PM   #2
68gmsee
Active Member
68gmsee's Avatar
Re: What to do about bowed hood problem..
Here's a picture of what I'm talking about. The bow is very slight and you seem to only notice it if you look down the center line of the hood.
Old 08-28-2007, 07:26 PM   #3
scrapmetalart
Junior Member
my 69 hood has it also...
frontstreetcycle on Instagram
scrapmetalart is offline   Reply With Quote
Old 08-28-2007, 09:38 PM   #4
Aarons72s
It is usually caused by the rubber that isolates the top of the hood and the 2 support braces wearing down. Mine, on the green truck was sagged pretty good cause they were gone and boards had been shoved in there place. Try getting new hood isolator pads and installing them or hammer on the support braces to tighten them up. That would be my guess and solution.
Aarons72s is offline   Reply With Quote
Old 08-29-2007, 12:59 AM   #5
CrashEd
72 chevy
CrashEd's Avatar
I got one truck the PO used yard sticks to shim up the hood lots of them too LOL!! it did look good though from the outside.
Iv seen some use spray in foam trimmed and painted.
Best would be new rubber pads like Aarons72s said.
Ed
CrashEd is offline   Reply With Quote
Old 08-29-2007, 08:43 AM   #6
68gmsee
Active Member
68gmsee's Avatar
I had thought of engineering a metal brace and weld it down the center for added strength, but that would be last resort. I will try the brace pad shims first. These are old and dried out.
Old 08-29-2007, 10:05 AM   #7
67_C-30
I have a radical idea!
67_C-30's Avatar
I have taken a piece of 1" X 2 wood put the 1" in section in the center hood in the center ridge and the other end either somewhere solid on the engine, and slowly and carefully shut the hood down on the the wood. If you do it carefully it and a little at a time, it will take the bow out the center ridge, and it tightens the whole hood panel up. Then you can put the shims under the braces to keep it from happening again. I have done this on several, and it has worked perfectly. Just be careful, and don't pull down hard on it.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435
‘72 C-10 SWB , 350 4bbl, TH350
'69 C-10 SWB , 250 L6, 3 OTT
'69 GMC C3500, dump truck, 351 V6, NP435
'84 M1009 CUCV Military Blazer
67 C-30 Turbodiesel build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=254096
My trucks
http://s226.photobucket.com/albums/d...ediafilter=all
Member of the 1-Ton Club!
67_C-30 is offline   Reply With Quote
Old 08-29-2007, 03:06 PM   #8
Mt Man Chad
Mt Man Chad's Avatar
I saw a show truck with a formed brace supporting the center of the hood it was tied into the two exsisting supports.
I'll see if I can find the picture of it??????
68 CST SWB - Gold/White 50th anniversary /TH350/Buddy Buckets/3.73 Posi/dogdish caps.
68 K10 Burb - Gold/White 327/SM465/NP205/3.73 "Daa Burb" build thread
Mt Man Chad is offline   Reply With Quote
Old 08-29-2007, 03:28 PM   #9
68gmsee
Active Member
68gmsee's Avatar
[QUOTE=67_C-30;2332136]I have taken a piece of 1" X 2 wood put the 1" in section in the center hood in the center ridge and the other end either somewhere solid on the engine, and slowly and carefully shut the hood down on the the wood. If you do it carefully it and a little at a time, it will take the bow out the center ridge, and it tightens the whole hood panel up. QUOTE]
... man I never thought of that one. I guess that's why we have this forum..
This is what I had thought of if the other tricks didn't work.
Thnx.
Old 08-29-2007, 03:43 PM   #10
Mt Man Chad
Great Idea !!!!!!!
I'll be fixing one of my 67 & 68 hoods tonight............
Old 08-29-2007, 05:34 PM   #11
67_C-30
67_C-30's Avatar
I think you will be very impressed with how it turns out. Just be easy with it, and check every time you out pressure down on it.
My trucks
Old 08-30-2007, 08:56 AM   #12
prg machine
prg machine's Avatar
Just finished my 68 hood with same problem. I used a small pecking hammer and dolly to bring the rib (spear i call it) back up straight, mine had been hit at the same point the above pic shows.
I then took 1 inch box tube slit it at one end inserted a tab and welded it to tube . The tab can be bent up appropriately to hook under the front of the hood where the spear ends and a small plate was welded across the face of the back of tube , pushed down to support center of hood and tack welded to the rear cross brace on hood.
prg machine is offline   Reply With Quote
Old 08-30-2007, 09:12 AM   #13
68gmsee
Active Member
68gmsee's Avatar
prg, thanks for the info. If the wood block on the engine method doesn't work on mine, I was going to do a brace job as you did. I had no idea how I was going to do it other than looking for an old hood and removing the brace and using that.
I like your idea. Any chance you can post a pic of it? Did you use any padding on top?
Old 08-30-2007, 12:14 PM   #14
prg machine
Yea. I will use a foam or rubber between the "gaps on my new brace as it is straight and the hood is not. I tried a block of wood perfectly formed to fit in the "channel of the spear inside the hood and a dolly on top and smacked it good at least 10 times. It did not move a bit. I pecked that area up with a dolly on the outside and it straightened in about 5 minutes!!!
