Old 04-30-2002, 09:58 PM   #1
Benrs86
Benrs86's Avatar
Post how tight rocker arms??
ok, today my 350 started running rough, not like missing, not like timing, it was just wierd, but anyway, im gonna check the timing and stuff and do whatever tomorrow but my dad said that i would need to retighten my rocker arms because they will wear in after a while. so i was trying to remember, i get the valve up then tighten untill the pushrod has no slack in it then another 1/4 turn right? thanks, Ben
Brandon, SD
69 GMC 1/2 ton 2wd
wide long bed with wood
3 on the tree
350 engine 4 bolt main
rv cam
AIM = Alphray04
Benrs86 is offline   Reply With Quote
Old 04-30-2002, 10:07 PM   #2
Fast68Chevy
Fast68Chevy's Avatar
Post
you do not need to maintain the rocker adjustment on these engines, that is only true though on hydraulic cam engines, did you put in a mechanical cam ?
theres no need to readjust rockers, the plungers are centered after first adjustment after engine assembly and there is 1 full turn worth of travel that can be taken up dut to wear, if they have worn that much then its time for new valvetrain
but if you know someone has messed with the top end of the engien in the past and think they may not have readjusted the valve rocker lash correctly, then get a haynes book open and find where adjustment procedure is, they explain it very well per GM specs, it is 1 full turn on the nut past zero lash at the rocker tip to vavle stem tip.
when the lifter is at the dead bottom of travel in its bore in the block that is when to adjust the rocker nut for that lifter, back it off til rocker is floppy loose, and then carefully tighten nut while wiggling rocker until the rocker straightens up(makes contact with valve stem tip) then tighten the nut one revolution, do the same for all 15 others when the lifter for that rocker is all the way down in the bore
if engine was just assmebled and you guys adjusted the lash correctly, then you wil never need to readjust ever, UNLESS you have a machanical cam
Randy- Lincoln, IL
randy@ccaonline.com 2177353230
-71 C-10 350/CH465/3.07, basketcase literally, am assembling now
-84 Z28 5.0L/700R4/3.73 daily driver
-84 Firebird/SE 2.8L/T-5/3.73/engine bad, dammit,,
-82 purple Trans Am, ram hood, junk305/good THM200C
**I buy/sell/hoard/trade most any GM vehicle parts of any and all kinds
-parting out: '81 Cutlass Supreme Brougham
*Paint is overrated
© RSS Enterprises 2000
[This message has been edited by Fast68Chevy (edited April 30, 2002).]
Fast68Chevy is offline   Reply With Quote
Old 04-30-2002, 10:23 PM   #3
69 longhorn
Post
You can run them @ 1/4 turn,be may need to readjust more often. Comp cams reccomends 1/2 turn preload,& that is where I run mine. The book says 1 full turn,but if you plan to rpm that perf eng up.......thats too tight. 69 longhorn
http://community.webshots.com/user/hotrodhorn
69 longhorn is offline   Reply With Quote
Old 05-01-2002, 07:55 AM   #4
Benrs86
Benrs86's Avatar
Post
cool, i will check everything today, ill go with 3/4 of a turn that way im in the middle. thanks, Ben
Brandon, SD
69 GMC 1/2 ton 2wd
3 on the tree
rv cam
AIM = Alphray04
