08-29-2007, 05:05 PM | #1 |
GVW 1 ton 4x4
Would the gvw for a 83 1 ton 4x4 be over 9000#? The tag on my door is gone.
-Lincoln 1987 GMC S15 (soon to be a chevy clone) 2.5l, 4 speed, no ps, no pb, no ac Silence is golden, but duct tape is silver. Spoken by Cletus the hillbilly I like stickers... a whole bunch. |
08-30-2007, 08:58 PM | #2 |
Re: GVW 1 ton 4x4
bump
08-30-2007, 10:00 PM | #3 |
Right turn Clyde
Re: GVW 1 ton 4x4
Post the fourth letter of your vin plate and I can tell you.
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73 1992 Camaro RS 305 TBI |
09-01-2007, 08:59 PM | #4 |
Next!
Re: GVW 1 ton 4x4
If you by chance have a CUCV 5/4 ton then yes. In that case your 3rd digit is a "D". (9400 for M1028s and M1031s, but 8800 for M1008s) If 4th digit is G, 9000 or less. H is 9001 to 10,000. F is 7001-8000. This info can be found in the front pages of your Service Manual.
86 K30 CUCV M1028A1 86 K30 CUCV M1028a2 dually 86 K30 C&C 6.2 4:56s, 4M, 11,000 gvw, ex fire truck, now lowboy dump More square bodies and CUCVs than I care to admit to 2020 Silverado K3500HD Work truck Last edited by GM72K10; 09-01-2007 at 09:00 PM. Reason: more info |
09-04-2007, 12:51 PM | #5 |
Active Member
Re: GVW 1 ton 4x4
The GVWR for a retail market single rear wheel K30 pickup is 9,200 lbs; it is 10,000 lbs for the dually version. An 8,600 lb. version was also available, but only for the 1977 thru 1979 model years.
So, in your case the 9,200 lb rating applies. Ken Lewis |
09-04-2007, 06:59 PM | #6 |
Re: GVW 1 ton 4x4
Thanks KIILew that's the first straight answer I have gotten thanks.
