Old 08-29-2007, 05:45 PM   #1
`68 327 alt mounting w/headers?
Can I buy an alt bracket for my 327 when I use headers?I know there are a/c brackets made for the "bossed" heads,`69-up.
Old 08-30-2007, 02:13 PM   #2
sneakysnake
It's a catastrophic success.
sneakysnake's Avatar
Re: `68 327 alt mounting w/headers?
You need a bracket like this.
http://hotrodchrome.com/alternatorbrackets.html
sneakysnake is offline   Reply With Quote
Old 08-30-2007, 02:37 PM   #3
kaycee
kaycee's Avatar
Thumbs up Re: `68 327 alt mounting w/headers?
Yep u need the #3027 and #3071 from the site sneakysnake mentioned those r the ones I'm using and have no problem.
2001 Silverado K-1500
2005 FXDWG stage3
69 CHEVY Short/Step 327/4L60 373 posi
63 IMPALA 327
kaycee is offline   Reply With Quote
Old 08-30-2007, 09:20 PM   #4
I don`t see how that could do any good to mount the alternator.What you need ar two holes facing the front.
Old 08-30-2007, 11:34 PM   #5
kaycee
kaycee's Avatar
The one pictured goes over the header tube,the other one mounts to that bracket and the ears of it mount to the botom of alt.Then u need an alt. arm #3028 that goes over to water pump or intake manifold.I know it works cause I've got the setup on my 327
2005 FXDWG stage3
63 IMPALA 327
Old 08-31-2007, 12:47 AM   #6
MDC
MDC's Avatar
Just like kaycee said. I got mine at PepBoys.
67 C10 Shortbed 327
05 F150 4x4 NO APPOLOGIES 's
02 Xpress X19 02 Yamaha VMax 150
www.xpressboats.com
Nothing says 'poor craftmanship' like wrinkles in your duct tape
MDC is offline   Reply With Quote
Old 08-31-2007, 05:53 AM   #7
OK,I figured a piece must be missing.It`s basically the same as the a/c header mount.Thanks!
