Old 08-30-2007, 06:31 AM   #1
tab a
rockers/valvetrain + oil = mess?
I replaced a broken rocker arm on my '72 350. Read through a number of old threads on adjusting valves, some of which said that doing it with engine running was really messy. How much oil should be flying around?
I really didn't have much, and wondered if this is suspicious for a lubrication problem? Engine was not really warmed up, and oil pressure was about 25#.
2. Did 350's of that vintage all have hydraulic lifters? If not, how would I know which I have?
Thanks!
tab a is offline   Reply With Quote
Old 08-30-2007, 06:57 AM   #2
bad6772
Official Site Guitar Shredder
bad6772's Avatar
Re: rockers/valvetrain + oil = mess?
only tip i have for ya ...in the mess dept is to take an old vavle cover and cut the center out of it.... leaving the bolt pattern...it will work as a valve cover should as far as catchin the oil. and still allow you access to the rockers...hope this helps ...tony
bad6772 is offline   Reply With Quote
Old 08-30-2007, 07:20 AM   #3
truckdude239
truckdude239's Avatar
25 pounds at idel sounds bout right the it should go up as rpm increase
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 08-30-2007, 07:32 AM   #4
cdowns
cdowns's Avatar
all truck 350 engines had hydraulic lifters there were solid lifter 350's in z28 and corvettes of the era but thats about it
Old 08-30-2007, 08:52 AM   #5
68gmsee
Active Member
68gmsee's Avatar
Re: oil flying around.
I've done this adjustment on several types of engines. Some the oil squirts out and others it just oozes out. I guess it depends on the condition of the engine (oil pump, bearings, built up grime inside push rods, etc.).
Last one I did was a new rebuilt engine. I had everything vatted and it made a mess. On my older 350 that I replaced the lifters on, oil just seemed to barely come out...
Next time, I'm going to look for some old valve covers to use as mentioned for precaution.
68gmsee is offline   Reply With Quote
Old 08-30-2007, 11:50 AM   #6
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
I also have an old set of valve covers that I cut the tops out on, plus I use a set of little metal slips that snap over the push rod end of the rocker. That way, I don't have the oil squirting out the top of the valve cover, and what runs off the end of the rocker can't flow out over the edge of the head onto the manifolds.
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
