Old 08-30-2007, 07:08 AM   #1
jimmycrown
new socks on sender
im in the pross of changing my gas tanks on my85 k20 due to rust .my questoin is can i change just the sock on the senders or do i have to change the whole sender .the both are acurate on the readings.thanks jim
jimmycrown is offline   Reply With Quote
Old 08-31-2007, 03:33 PM   #2
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
Re: new socks on sender
you can replace just the socks if the rest of it is ok.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 08-31-2007, 08:42 PM   #3
xtreme80
Wishin' I had more money!
xtreme80's Avatar
If you find a place to buy JUST THE SOCK please let me know...
I looked at Napa, Autozone, Checker, Pro auto parts, the dealership, LMC, and many many online stores to try to find just the sock, and couldn't find a thing. If I remember correctly also, the sock is permanently attached to the metal washer on the pickup tube.
Good luck with this one. I'll be watching to see what you come up with.
xtreme80 is offline   Reply With Quote
Old 08-31-2007, 08:57 PM   #4
Duro5341
Duro5341's Avatar
You can replace just the sock/strainer, however if your replacing the tank due to rust, and stuff....sounds like for the whole $60 the sender will cost, I would just replace everything Tank, Sender...a sock will come with the new sender
Duro
-1986 K10 LWB, 350 HD,TH400
3.08, 30 spline 10 bolt, with an Auburn Posi, 31" tires
All original, second owner truck
-1979 Monte Carlo, 350, 200r4, 3.73 posi
-1987 GT T-top Mustang - slow moving project
Duro5341 is offline   Reply With Quote
Old 09-02-2007, 02:37 AM   #5
bad6772
Official Site Guitar Shredder
bad6772's Avatar
you might try advance auto? im not shure if they are in your area, they seem to have parts that i never can get anywhere else? im going there tuesday, i will look for you guys... its just a standard sock? by its self with out the pickup tube?
bad6772 is offline   Reply With Quote
Old 09-02-2007, 05:32 AM   #6
MylilBowTie
Right turn Clyde
MylilBowTie's Avatar
The "sock" is a fuel pump strainer. ACDelco Part # 5651711, Im sure there are more part numbers and brands.
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73
1992 Camaro RS 305 TBI
MylilBowTie is offline   Reply With Quote
Old 09-02-2007, 11:33 AM   #7
jimmycrown
i caled a local dealer a guy there said he could get them supposed call after holiday will keep u posted and hopefully some pics
